Jeep swap
Box Stock 2004 TJ 2.4 5spd = 17-18mpg
Same TJ with 35's and a 4.5" long arm = 17-18mpg
Add 5.3/4l60e =17-18mpg
Swap factory 4.10's for D44/8.8 w/ 4.88's.... 17-18mpg
In conclusion, Jeeps are bricks and get what they get
Yea my YJ is currently about 3800lbs, the ****** weighed about 2600.. Lost track of it but the 3 owners after me all ended up in the ditch somewhere.. Driving a jeep is like driving with your drag chute deployed ... LOL For Floader- My gmc Yukon xl is the same way! 10-11 mpg pulling a trailer or empty!
For PDX- That will be an adventure! I've heard that the road rattles the **** out of everything! Can you say Loctite!
Got the trans mount welded up and painted. Set it outside to dry and came back to find crows had perched on it and **** all over it! Wife is blaming the millennial next door for playing angry birds in HD!
The intake has no chance of fitting between the block and the radiator. Last night I figured out the upper radiator hose. I cut off half the water neck to get the space needed to run the hose.
The paint is duplicolor metalcast. I used their primer, paint, and clear. It's like a pearl metallic.
I need more clearance to rotate the t/c upward. Front drive shaft will hit the trans linkage and vent on top of t/c is too close to the body. Considering lowering the trans mount to gain room. To do this, I'll remove it first and rotate t/c then lift it into the zone. Then connect everything and look for problems. Meanwhile there are plenty of little items to connect. The pic's of your guys projects give me hope. Thanks!
http://
