Jeep swap
Hart Rod- I splurged and got the shifter from speartech. It has the push button switch on the shifter for selecting gears. I will need to get their gear selector light and wire it in so I know what gear it's in.
I just dropped my engine over in my Jeep and I feel I need to bring my engine forward about 1/4" over the recommended tabbed positions. Also, in the recommended locations, its wasntinh to kick the tailhousing of the tranny 1" over centerline.
I'm planning stock exhaust manifolds right from the get go, For my purposes the stock HP will be more than enough and it will keep the exhaust plumbing simpler.. I have a friend at a local yard watching out for a good candidate for a engine package pull. I want < 80K miles if I can find it.
Gotta start ordering the misc bits from Novak and others.. While paying college tuition...
The rear bumper is more of a mount for the tire carrier. It came with two holes for lights. So I had to drill holes in the cross member for lights to bolt through.
Stock fuel module and guts.
Used my dremel to remove the ears from on top of the plastic housing and the post underneath it. Here are my fittings, pump and hard line.
Bottom view of innards and pump housing that I cut around 2 inches off the bottom. The hard line next to the pump is my return line and will be pointed towards the pickup on the holley hydramat.
Here is the top of the module. I know...the plug with JB weld looks tacky! For those who do this mod: the freeze plug is a 34mm and was tapped into place prior to slathering it with JB weld.
Plus this is likely the last car build for me, I have other extended plans and just this once,, I'm going way north..
Id go big Hemi but the $$ are too high and its a harder swap.. I had a 400HP 327 ****** many moons ago, so i know what too much is like LOL, hoping the extra width of the YJ and the extra wheel base tames it.. (a little)
