LSA blower on a 5.3?
This is what is looked liked after I prep'd it for the turbo. The Holley intake has already gone to another good cause as part of the LSA swap. Only parts I'm missing are a different water pump for the brackets, LSA damper and LS9 valve covers. I haven't figured out if the cam for the turbo can be used. I'll find out if it works.
DaveB
Seems to me there is nothing budget about a blower build. if you are going through the expense of a blower will it really break the budget to start with a larger bore bottom end?
I could understand the cost of the adapter plates if displacement was limited by some class rule.
To anyone buying these superchargers don't forget why GM is replacing the whole supercharger and not just replacing the failing coupler, When the couplers fail they wear the shaft on the supercharger and the metal from the shaft end up contaminating the supercharger bearing and the bearing will eventually fail. You might get lucking and get one that hasn't had the chance to cause any damage but that's the chance you're going to take.
You will also want to price everything needed because the supercharger itself is only a small part of the cost. I paid $1475 for a new supercharger with fuel rails/injectors/sensors/bypass valve and $387 for a new ZL1 lid. The rest of the money is all the stuff needed to make it all work. Just the supercharger/accessory drive is going to run you anywhere from $800-$1500 depending on what you use. Choose carefully because there are some systems on the market that are poorly designed and you'll likely end up with belt slip. I'm going to use a combination of stock CTS-V supercharger drive and corvette A/C bracket and Holley corvette alt/ps setup.
