Aftermarket oil temp gauge sikky oil pan
Hey guys, almost ready to drop my Ls1 in my bmw E30, I already have the autometer adapters for my coolant temp and oil pressure gauges. My question is since I'm running the sikky swap pan and the ports above the filter isn't there anymore where else can I put an oil temp sensor?
sawzall wielding director
Yep, theres also a port behind the intake up by the cam position sensor. If your LS1 has the single wire oil pressure sensor take it out and run yours. If it has the 3 wire sensor either put a T in and run them both, or you may have to turn a code or 2 off in the PCM ( The pcm does monitor the 3 wire sensors, but I can`t remember if it has any check engine light codes enabled for it).
