Lsx swap motor mount?
Trying to put a 4.3 in a 91 camaro I have the clam shells now do I use my truck motor mounts (on the block)with the adapters or do I need a different set?
I couldn't find a swap forum section.
I would say yes. I would get engine tranny mated and put mounts on engine with clam shells on so you can see if any holes on frame works. If no make sure motor and car is level mark where needed. Drill holes or weld them down. I like bolting it tho.
