Harness Rework Tips
I have enough experience with wiring practices that I'm not really intimidated by the project, but I haven't had to rework this many circuits at once before. I've read stevesnovasite and lt1swap.com, and all that makes sense. Please excuse any dumb questions, though.
- The Dakota Digital stuff came with their sensors and adaptors. Should I use them, or the ones already in the motor?
- Is it worth the trouble to reloom everything? I'm not above just chopping plugs off. I'm building a daily driver.
- What is a good work strategy- do it mostly on a workbench, or in situ? I am thinking it would be best to do most of the work in the engine bay... Lay out the harness and hook everything up, and then start working backwards from the things are gone.
- Where can I source an OBDII port for under the dash, and where does it hook up to the harness?
- Should I add relays for the headlights or any other big power draws while I'm doing the fuse block and fan & fuel pump relays?
- Is it worth the trouble to mount the PCM behind the dash?
Thanks for any help. I'm sure I'll have more questions as I work through this.
It's time consuming, but worth it to re-loom your harness. It will make for a much cleaner install. The F body harness you have is damn near stand alone as it is and easy to convert over.
I tend to lay the harness out over the motor and identify and label everything. I then remove the harness and set it out on a table where it will be easy to work on. Do yourself a favor and buy a roll a pvc harness tape. Amazon sells the tape cheap and you can find the high heat split loom there as well if yours is too old and brittle.
OBD ports can be found on ebay, amazon or your local wrecking yard.
Relay for the headlights are not a need, but always a nice way to do them.
Mounting the PCM under the dash all depends on your harness length and mounting location. It makes for a clean install, but if you've got to make the trunk of the harness longer it's a lot of work.
I was just barely able to get the PCM connectors fed thru the existing ~Ø1 1/4" hole in the firewall, and extended a couple wires to make it easy to locate the PCM inside. I haven't decided where to put the PCM yet. I may eventually add Classic Auto Air system, and don't want to have to relocate it for that. Anyone have any suggestions or pics of their setup?
I believe the best way to do the coolant temp with a DD dash is to purchase a CTS from a 97-98 Corvette which has 3 wires, one of which is a feed for an analog gauge. I have the sensor and pigtail on order, but does anyone know which wires I connect to what? Is it just a common ground, and two identical outputs?
My Classic Autowire kit feeds several circuits through the fuse box / bulkhead which could now just live inside the cab. What have folks done with this? Just join them into the harness under the hood, and back into the cab?
Thanks for the help.
Yes, I pulled out all the unneeded circuits.
I'm using the 3-wire 98 CTS, just need to know which 2 pins go to the PCM, and which one to the gauge?
I like the idea of the PCM being indoors, but I will take another look at mounting it under the pass fender. I lengthened whichever sensor it is on the back of the intake that pulls tight first, so it's no longer the restriction. Would I have to lengthen every wire in the harness, or is that enough? How hard is it to remove the PCM under the fender? Any pics?
Thanks for the reply.
