Wiring basics
Old Mar 10, 2016 | 11:17 AM
jozw30's Avatar
Running ground to block.
1. Can these wires be run through the interior compartment or is it best to go through the floor and down frame?
2. Still looking for a good answer on fusing the positive cable near the battery. Have heard it's a good idea and heard it's not a good idea......
Thanks,
Joe
Old Mar 10, 2016 | 11:21 AM
Project GatTagO's Avatar
Thanks,
Joe
Joe,
1. Either way will work, although running them along the frame will be easier.
2. I run the positive cable straight to the starter, no fuse (GM has done this for decades).
If you don't want that long + lead down the frame to be "hot" all the time, you can install a Ford starter relay in the trunk. This is common practice so there should be ample information about it.
Andrew
Old Mar 10, 2016 | 11:39 AM
jozw30's Avatar
Thanks Andrew, I will research the ford solenoid idea.
Gonna sound really stupid maybe, but if the main cable is not hot all the time, how does power get to the fuse block? Do you then have to run an additional/separate positive to the front of the car?
Old Mar 10, 2016 | 11:46 AM
Good question, and I honestly don't know. My guess is that you have to run a separate feed to the fuse panel.
Andrew
Old Mar 10, 2016 | 12:02 PM
jozw30's Avatar
Just for fun, voltage drop in 12' of 1/0 gauge wire on 12vdc 200amp circuit is 0.24v.
In a 2/0 gauge it is 0.19v.
Hardly worth worrying about in this application, I would think.
This is just the wire. I guess we're assuming good connections that don't add resistance.
Old Mar 17, 2016 | 11:35 AM
Marky522's Avatar
I mentioned above that a 200 AMP fuse is cheap and readily available. http://www.delcity.net/store/MEGA-Fuses/p_800374 I use one on my 5.3 Swapped S10 Blazer, with chassis ground...... sorry, i had to..... havent had an issue with the fuse ever.
- Great suggestion regarding the ford solenoid Project GatTagO, never thought of that and i really like it.
Mark
Old Mar 17, 2016 | 06:42 PM
jozw30's Avatar
Marky522, is your fuse on the positive or ground side? I've read not to put it in the +.
Old Mar 17, 2016 | 07:12 PM
Mark
Ford had done this for decades. I never really understood it until I started working on my Cougar. Once I figured it out, it made a lot of sense. My battery is in the engine bay, but the only + lead that is always hot is the 6" battery cable that goes from the battery to the solenoid.
Andrew
Old Mar 17, 2016 | 07:30 PM
Marky522's Avatar
Positive, right at the battery.
Old Mar 17, 2016 | 07:31 PM
Marky522's Avatar
Andrew
I was aware that ford had used that setup, just never dawned on me to steal the idea!
Mark
Old Mar 17, 2016 | 07:38 PM
Mark
Electrons don't discriminate between car brands...LOL
Andrew
Old Mar 18, 2016 | 07:52 AM
  #32
jozw30's Avatar
This extra solenoid makes sense, but nobody answered the question about how you get the 12v to the fuse panel that's needed all the time?
Trying to think if my build has any systems or devices that need 12v all the time for memory or clocks and such.
If it does, I'd have to run separate positive for that from the trunk so it doesn't really make sense in that situation.
Am I missing something?
Joe
Old Mar 18, 2016 | 09:38 AM
  #33
ls1nova71's Avatar
Yes. you'll have to run a power wire for the fuse box from the battery. You will also need to run a pretty decent size wire from the battery to the alternator if you want the battery to charge, so if it were me, I would just run the battery cables to the engine.
Old Mar 19, 2016 | 05:16 PM
  #34
jozw30's Avatar
I'm just going to add the fuse and run the positive wire to the starter. I don't understand the benefit of the solenoid on the 1/0 main wire if I'll have to run a secon, smaller gauge wire and let it be hot all the time anyway?
I'm sure it missing some important point/fact.......
Old Mar 20, 2016 | 03:36 PM
  #35
jozw30's Avatar
Ran 1/0 ground from battery to rear of right head. Is a 1/0 ground from rear of left head to frame good?
Plan to also run a 1/0 from frame to body. That should be good enough, right?
Old Mar 20, 2016 | 06:38 PM
  #36
kwhizz's Avatar
I always run the ground to the engine block, whether the battery is in the trunk (my GTO), or under the hood (my Cougar).
Andrew
x 100
Old Mar 20, 2016 | 06:39 PM
  #37
kwhizz's Avatar
Yep !!!
