5.3L + 1993 4L60e??? What do i need to do to make this work right?
Long story short Im tired of the BS TBI crap in my 1993 Chevy K1500 4x4 and so i bought an 03 5.3l LM7 to swap into the truck. Im dead set on using the early non-PWM 4l60e thats in the truck now becuase i just had it rebuilt less than 15k miles ago. So I have already purchased the the machined crankshaft spacer/adapter with the six holes in it. Can I or can I not use the stick dished 5.3L flexplate with the spacer? Does the spacer go on before or after the flexplate?
About the trans... i thought i read that I could get a newer 1995+ harness and tcc solenoid and put it in my transmission to fool the computer. Anybody know?
Stock dished 5.3 flexplate will work, dont bother getting the bolt on spacer and longer bolts just get the stepped ring looking one. As for the trans not sure i think yours only uses a 12 pin connector and the 95+ use like a 14 pin, no clue what the differences are but i read it wont work. Im doing the same swap in my 1996 tahoe
Check out the automatic trans section on this site.If mrvedit and clinebarger say no,it is more than likely true...
https://ls1tech.com/forums/automatic...to-1998-a.html
