LSA Swap - A/C Question
Old Apr 5, 2016 | 09:08 PM
NorCalChevelle's Avatar
Default LSA Swap - A/C Question
Hey guys, maybe someone hear can help me out. I'm looking to find out what bracket (and compressor) guys that have done this swap into A Body's have used. I'm in the process (slowly in the process) of putting my LSA together to go into my '72 Chevelle (using Holley's forward engine mounts as well). Of course, now I want to put A/C on it. I need to know what A/C brackets are available that will work with the GM Modified FEAD (I already have this FEAD for my LSA).
Here's the link to the FEAD, in case anybody wants/needs to see what I'm referring to: http://paceperformance.com/i-1999062...em-w-o-ac.html
I want to use a Vintage Air setup, but need to know what has worked for folks that have done this swap already (that doesn't require notching or purchase of another FEAD). Any assistance would be appreciated.
Old Apr 5, 2016 | 09:20 PM
user 4737373's Avatar
You might want to check out korndawg's build thread as he's just one step ahead of you on basically the same swap.
Old Apr 5, 2016 | 09:53 PM
john 67's Avatar
Kwik makes a low mount bracket for the sanden sd7 compressor , uses the single a c belt with its own tensioner . look through the thread "lsa blower swap" theres a pic in there . I just purchased one for a 67 impala build with the same fead . there is no pic on their site of the bracket yet. JOHN
Old Apr 5, 2016 | 10:17 PM
Thanks. I noticed no pic on their site.
Toddoky, I reached out to korndawg to see what bracket/compressor he mounted.
Old Apr 5, 2016 | 11:46 PM
ls1nova71's Avatar
If a low mount bracket is what youre looking for, this may work, but not sure if it would require a notch or not. http://www.alangrovecomponents.com/LS.htm
Old Apr 6, 2016 | 01:02 AM
Thanks. It might fit, but hard to tell from pictures (unless someone with an A Body with Holley's forward engine mounts has used it). I don't want to notch. Low mount is preferred.
Old Apr 6, 2016 | 08:48 AM
33willys's Avatar
Default A/C brackets
For what it's worth department, here is a picture of a low mount on my '39 build. Took about 5 tries to get the mounts right because it is so tight between the engine and crossmember. I have it on the road now and it doesn't throw a belt or hit the crossmember with engine torque. Making up the hoses was a whole different story. Had to make a wrench. If you do a low mount try to make up the hoses before the sheet metal goes on.
Attached Thumbnails LSA Swap - A/C Question-front-end-005.jpg
Old Apr 6, 2016 | 09:16 AM
wyattroa's Avatar
I am trying to figure out he same thing. I am going to be running a turbo and cant find too much with the AC and turbo.
Old Apr 6, 2016 | 09:42 AM
korndawg's Avatar
http://www.crateenginedepot.com/LSA-...06-P11003.aspx
Fit great w/ no modifications
john 67's Avatar
Pics on page 5 of this thread
https://ls1tech.com/forums/conversio...er-swap-5.html
Old Apr 6, 2016 | 12:24 PM
Thanks fellas! A few options out there thanks to your info
Old Apr 8, 2016 | 11:44 PM
Originally Posted by korndawg
Darn, the compressor included with this kit won't work for my application (Vintage Air requires fixed compressor, not a variable like this one is).
Old Apr 9, 2016 | 09:21 AM
You should be able to find a bracket to mount a Sanden SD7 in the same location.
Old Apr 9, 2016 | 01:49 PM
Ok. A member on another site has a SD7 bracket. I'm going to have him ship to me to test fit it. Correct me if I'm wrong, the SD7 is the "mini" compressor folks refer to (smaller than the Sanden 508), correct?
Old Apr 9, 2016 | 02:00 PM
kwhizz's Avatar
I was reading about the spec's a while back and as I remember the SD-7 actually has more Capacity than the 508............
Ken
Old Apr 9, 2016 | 02:40 PM
Kwhizz is correct, the SD7 is of larger displacement than the 508.
Old Apr 11, 2016 | 07:58 PM
Chevy Kid's Avatar
The 7176 is the small Sanden compressor...
SD715 is the 7 cylinder and has a higher capacity than a 508. Sometimes referred to as a 709.
Tim
Old Apr 11, 2016 | 09:25 PM
Tim
That's it, knew it was one of them that was the small one.
