LS3 525 Cobra kit car
And so it begins! Last week I got my LS 3 376/525 Connect & Cruise T-56 package! This is going in a Classic Roadsters Cobra Kit car I have had for about 10 years! It’s replacing a SBC 388 and 700R-4. This is my first LS motor so I’ll be asking a lot of dumb questions!
With the LS motor and T-56 it should tip the scales at under 2400 pounds with my fat butt in it! It has a Ford 8.8” rear-end with 4.11 gears and 28” tall tires, M/T DR 295/55/15. It’s a street toy with a trip now and again to the ¼ mile. I already have a 125 hp fogger setup, remote bottle opener, dash mount NOS and fuel pressure gauges with warning lights, so what the heck! It’s NOT going to be a show car and I only want to impress/scare myself! Retiring and moving to Florida in the near future and plan to do a lot of cruising and day trips!
First couple of dumb questions;
Cam change, what?
Planning 1 7/8” to 2” to 3 ½” collectors to 3” ID side pipe mufflers. Thoughts?
Any suggestions on a surge tank for the cooling system, steam line to where?
Using the stock fuel rails? Putting a sump in the tank, planning a loop near the tank with pump a T to the fuel rail using -8 lines, regulator and return to tank. Regulator to fuel rail about 5-6 feet. ??
I already have lines and oil cooler, adapter at the oil filter like the SBC?
Thanks,
Al
Cam change, what?
Thanks,
Al
Cool project. I wish I was able to fit in one better. I've wanted a cobra replica my whole life. Rented one but had a terrible time with the narrow foot well with the pedals. I sort of went home and cried.
If you are thinking of a cam change than why are you buying the 525 HP version of the LS3? The only real difference between the different HP crate motors is the cam, so wouldn't you save a few bucks buying the cheaper one?
Having said that I'm reasonably certain the 525 motor will scare the bejezus out of you in such a light and short wheelbase car. Plus will be a perfect cruiser.
Steam line, plenty of options written up on here. I tapped a fitting into the waterpump for a cleaner look. If you are careful when you fill the coolant you can plug the steam lines. People get mad at that but lots of threads arguing it, no sense arguing it again.
