08 Trailblazer SS With A TR6060
Old 04-21-2017, 10:31 AM
branndonw's Avatar
Not yet lol
Old 04-21-2017, 05:57 PM
Redbull87's Avatar
Thats freaking cool swap.That squeak would drive me nuts too...it sounds just like my clutch pedal.Im using 02 camaro pedals and found that the squeak was from the helper spring.Sprayed it with some grease and its gone.
Old 04-21-2017, 06:32 PM
branndonw's Avatar
The squeak is gone and the windshield is fixed lol. I attached the m/c pushrod a little lower on the pedal than the stock location and the push rod was rubbing against the hole on the clutch pedal mount. Went back and made the hole a little bigger and no more squeak.
Old 04-21-2017, 09:44 PM
HioSSilver's Avatar
Very cool!
Old 10-16-2017, 12:31 PM
Hibs's Avatar
Love the swap! Still driving good?
Old 10-16-2017, 09:10 PM
branndonw's Avatar
Thanks! Yep still drives great. No issues.
Old 10-16-2017, 09:14 PM
Hibs's Avatar
I've made contact! Sweet.... care to share, what the clutch pedal was out of? SSR?
What was the reason for the ECM Switch? And the harness re-pin was just to accommodate the switched ECM?
I would love to duplicate this build.
Old 11-23-2017, 09:46 PM
Hibs's Avatar
OP, any answers to my questions above?
Old 11-23-2017, 10:58 PM
Chased's Avatar
this is needs to be a sticky!! It would make me want to keep my SS
Old 11-25-2017, 04:17 PM
Tig
Tig's Avatar
Originally Posted by turbo_bu
Can you share what you ended up doing to get the ECM working? I remember reading about some of the earlier issues you were having. Just curious if you ended up having to swap ECM's since it's a 2008 TBSS.
This and if you could answer Hibs to
Seems like a lot of people would love to know, including me.
Old 01-13-2019, 07:37 PM
TheRace1092's Avatar
maybe i missed it, but were you able to retain the stock 08 tbss e67 and flash it for a manual trans so it controlled the reverse lockout speedo and such? i found a e67 and harness for one and plan to run a t56. id to know before ordering. thanks
Old 01-14-2019, 06:58 AM
  #32
TipsyMcStagger's Avatar
From Post #2.
Lingenfelter TRG-002 module modified and installed where the TCM used to be.
Quick Reply: 08 Trailblazer SS With A TR6060
