Beat to death alternator
Old May 11, 2016 | 02:04 PM
OmenNova's Avatar
Default Beat to death alternator
I have a question that has been beat to death, but I can't seem to figure out the final verdict of what people are doing recently. I got my Nova swap running, but the alt isn't charging. It's a C5 GMPP kit and has the SFL terminals. I wired 12v keyed to the L wire through a 194 build holder I had. The alternator won't charge. It also won't charge if I add 12v to the F wire. S is ran to the battery post on the back. I know 12v is supposed to burn up the L wire but I tried it very briefly just to see what would happen. If I touch 12v to it, it jumps up and charges 13.8 but won't work with the resistance method. Also there is a black line on the L part of the alternator like someone marked it from factory, not sure why. I don't want to burn it up obviously but I can't find any recent threads that addresses this either. Opinions?
Old May 11, 2016 | 05:16 PM
OmenNova's Avatar
Also the alt part number is 25888970
Old May 11, 2016 | 05:49 PM
Pop N Wood's Avatar
Take it to a parts store and have it tested
Old May 11, 2016 | 05:54 PM
OmenNova's Avatar
It has to be good though doesn't it? For the split second I applied 12v to the L terminal it charged.
Old May 11, 2016 | 06:42 PM
CBM Motorsports's Avatar
What resistor did you try using? It has to be a certain one or it wont work.
Old May 11, 2016 | 06:48 PM
OmenNova's Avatar
The resistor I tried probably wasn't right, it's just one I had laying around from some autometer gauges. The 194 bulb is what I initially tried though, seemed to be a common solution in a lot of threads. Is it possible the bulb reduced too much and didn't activate it? May just have to order the 470ohm.
Old May 11, 2016 | 07:42 PM
BigBadWhitey's Avatar
Any idea what voltage is suppose to be ran through the L wire?
I seem to be the other way - im worried my alternator is always charging. Any good way to tell?
Old May 11, 2016 | 08:24 PM
OmenNova's Avatar
Everyone says the L wire should have 5V
Old May 13, 2016 | 05:47 AM
Pop N Wood's Avatar
You are going to be really mad at yourself if you go through a bunch of effort only to find the unit was bad.
Old May 13, 2016 | 07:02 PM
70 Bug Mid Engine's Avatar
This is the one I know for a fact works. And it goes in this location on the connector.
Attached Thumbnails Beat to death alternator-20160513_170013.jpg   Beat to death alternator-20160513_170355.jpg
Old May 13, 2016 | 11:03 PM
OmenNova's Avatar
I messed around with it some yesterday and used a different bulb socket. Inline with the L terminal the alternator now charges fine. Just an issue with the holder I was using I guess. The bulb does stay lit up though once I start the motor at idle. I assumed it should go out but doesn't.
