Connector iden 5.3/4.8 with 99-01 camaro harness, psi ecm
Hey guys done a few ls1 swaps before but always had the correct harness to match the engine and wiring was very simple. I came into a project at this newer shop and some guy wired up the engine with a truck harness that was all cut up and what not had no spark and no injector pulse, I checked all the pins in the ecu for power and checked all the plugs on the engine for power/ground and everything checked out anyways trashed that harness (full of harbor freight junk connectors and house electrical nuts and owner supplied a 2001 camaro harness (he thinks), there are 5 body connectors 2 10 pins with water seals, 1 8 pin with a water seal, and then 2 that go behind fire wall that are blue and white, with out cutting anything I just shoved in some wires to the connectors for power and ground turned on the fuel pump manually, and the thing fired up, map only waiting on the maf, there were a bunch of vacuum leaks and the throttle response was very poor not sure if it was the leaks or no maf or a combination.
Anyways getting ready to properly wire the thing up and I have a few connectors that I can't identify, I have figured out the three wire maf/mas connector and the 4 4 wire o2 sensor connectors, but there are 7 engine connectors I can't identify and then 2 other connectors on an extension from the main harness that are next to the downstream o2 sensors, one is a big round female gray connector (auto trans?) and a small 2 pin black connector with a green blk stripe and brown wht stripe (might be purple), I know I can trace all the wires back to pins on the ecu but I'd like to identify them before I remove all the split insulation and make a mess.
Ok well this photo uploaded is giving me funny buisness and pls don't tell me go use the function I've spent at least 6 hours looking related harness info, maybe we can figure out exactly what harness this is take a photo of each connector with identification and sticky it, the only thing I've found close to This is a 2004 Gti harness laid out with connectors numbered but no close ups with individual connector and wire color, I found wire color and a picture of related sensors On a website but only for a few main sensors
The photo with missing seal is on the same leg of the harness as the 3 pin maf connector and has a tan and purple wire (iat?)
Photo with gray connector and dual snaps has a black and a green wire and is located up near throttle body and is on the end of the leg that connects the passenger side injectors
Only wants to let me upload one or two photos at a time this one is on the same leg as the above gray with 2 snaps connector and has 5 wires from socket A to E we have white black brown white red, was thinking this could be for drive by wire?
This red connector is right next to the above tan connector but closer to the front of the engine and has a pink wire and a green with white stripe
ITS EVAP PURGE
ITS EVAP PURGE
Connector i described in first post on the leg with rear o2 sensors and big round gray plug, plug in photo is black has green with black stripe and a brown / purple with white strip possible this is the speed sensor?
Last post This is a three wire plug with purple in a socket gray in b socket and red with blk stripe in bottom hole socket c I pressume, This connector is located with in 8 inches of the red ecu plug and extends another 8 inches on its own leg from the harness, looks exactly like the plug used on the pressure sensors, there's also that vacuum line that pops into the harness near the rear of the intake manifold and pops out in the leg that has the 2 interior body plugs possibly for vacuum controlled a/c flaps? And finally there is 2 wires brown and black with white stripe that are in the leg of the starter solenoid and passenger front o2 sensor, the plug was cut off so I have no idea what it's for. THANKS FOR ALL YOUR HELP GUYS!
