E67 ECM Pedal options
Old May 27, 2016 | 08:23 PM
Slowjammin's Avatar
Default E67 ECM Pedal options
I had a 2009 Trailblazer SS LS2 swap completed in my 72 Chevelle. The TBSS pedal sticks out bad and I am looking for a different type of pedal. I ordered the Chevrolet Performance 10379038 pedal and it does not work. Im guessing its not reading it because its not compatible with an E67. Does anyone know of any pedals that will work that are similar in design as the 10379038? I cant find any pedals that work with an E67.
Or does anyone know a list of pedals that work with the E67 ECU
Thanks
James
Old May 27, 2016 | 09:05 PM
aknovaman's Avatar
It depends on what operating system and vehicle file is loaded in your e67 ecu.
Old May 27, 2016 | 09:18 PM
Slowjammin's Avatar
so there are different set ups for a stock 2009 LS2 TBSS? The car was never dyno tuned either.
Old May 28, 2016 | 08:28 AM
cpd004's Avatar
I'm looking for the same thing as you are. I was told an Impala or Monte Carlo SS pedal will work, but have yet to verify. I believe 08-09. I have a Corvette pedal that I haven't tried yet. When I do, I'll post in this thread.
I'm currently running a 2007 TBSS E67 with a silver blade throttle body and a stock 2011 Corvette Ls3.
Old May 28, 2016 | 07:17 PM
cpd004's Avatar
Well, no go on an 08 Impala and 11 Corvette pedal. I'm not sure what else to try.
Old May 29, 2016 | 10:32 AM
showdog75's Avatar
Cadillac cts-v used the e67 ecm.
Old May 30, 2016 | 08:30 AM
cpd004's Avatar
I believe that is the same part number the OP listed as not working.
Old May 30, 2016 | 01:06 PM
EFIHARNESS's Avatar
We have used all of these with the E67.
1034 5632
1583 1256
2583 0024
1588 4314
2583 0024
gmpp 1036 7117
BWD pps1123
standard asp128
echlin or napa 280027
airtex 557944
carquest 72-7031
E rod or 2011 cts 1037 9038
camero 2274 1799 cheap $42, works well
There are plenty more.
You may have to reverse pins a and c as the trailblazer pedal connections are different than most
other gm cars. The other pedals you have will work.
If you weld on the metal pedals to change the shape, be sure to heat sink away from the sensor or you will damage the
carbon traces. Steve
Old May 30, 2016 | 10:56 PM
Project GatTagO's Avatar
I like using the 2009 Impala SS pedal.
Andrew
Old May 31, 2016 | 06:19 AM
aknovaman's Avatar
The whole story is not being told here to help this guy. The pedal range and limits are hard coded in the ecu and are not changeable via Tunercat, HPT or EFI live even if you do a write entire. If you try to use a different pedal that does not match the limits set in the ecu,it will not function correctly and set codes as well as not go from zero to 100% range,even if you match the wire colors.
That being said, the only way to use a different pedal is the totally reprogram the ecu with a file matching the pedal limits via a tech II. So either reprogram the ecu or modify the existing pedal to physically fit the Chevelle.
Old May 31, 2016 | 04:43 PM
Slowjammin's Avatar
I didnt know that. I appreciate it. Speartech sells a bracket . It currently show out of stock though, but I left them a message. Hopefully they get back to me soon. I want to know if this bracket will mount to the 1972 Chevelle, and also place the 09 TBSS pedal beneath the brake pedal. I believe the stock or ideal location for a gas pedal is 1-2 inches beneath the brake pedal.
Old May 31, 2016 | 05:50 PM
aknovaman's Avatar
The e67 ecu is used in a multitude of Vehicles including Ecotec 4 cylinder cars, v6 impala and also different firmware in the copo v8 Camaro. The SandRail guys use the mefi e67 ecu which has a different pinout compared to 4 cylinder Ecotec HHR. The mefi ecu can only be programmed with overpriced proprietary software. Total pita.
Old Jun 10, 2016 | 05:56 PM
Slowjammin's Avatar
1034 5632
1583 1256
2583 0024
1588 4314
2583 0024
gmpp 1036 7117
BWD pps1123
standard asp128
airtex 557944
carquest 72-7031
I appreciate the info sir. Im looking at the Camaro 22741799. Did you have to switch the a and c pins for that aswell?
