DR44 alternator wiring
I've got a DR44 160 amp 4 pin alternator on my 5.3 in m '70 Nova. I've got the main lug hooked up and had pin "B" hooked up as well which came from the gen light circuit (brown wire). With the engine running, the alternator was charging 13.5 volts, but I know that's the default charging rate. Realizing later that I didn't have a bulb in the gen socket, on the dash, I was wondering if I'd see higher than the 13.5 volts with the bulb in place. I haven't had the car running yet since I replaced the bulb. Also, do I need a "sense" wire hooked up to another terminal on the alternator to see 14+ volts? I know some say yes, but where would it come from? "Just from the fuse box" doesn't tell me much. I know there's plenty out there, but I'm looking for experiences.
