Looking for a low mount AC bracket that is inline with other accessories
Old Aug 4, 2016 | 01:47 PM
samckitt's Avatar
Default Looking for a low mount AC bracket that is inline with other accessories
Is there an AC bracket for an SD7 compressor that puts the pulley in line with the rest of the Vette accessories. I need one that pushes the compressor forward to remove or reduce the amount of notch required on engine crossmember.
Does one exist?
Thanks
Old Aug 4, 2016 | 03:39 PM
130fe's Avatar
Are you talking about leaving the compressor in the stock position (pass lower) or mounting it up pass high side (like the Holley bracket)?
Old Aug 4, 2016 | 03:49 PM
samckitt's Avatar
Low near stock location. Why would I need to notch front cross member if mounted high like holley bracket?
Old Aug 4, 2016 | 07:10 PM
john 67's Avatar
Kwik makes a bracket ,not sure if it is on there site yet but someone on here has a pic of it , I bought one for a 67 impala and it fits nice .It uses the small belt for the ac only and comes with its own tensioner, I'll look for the thread What is it going on ? JOHN
Old Aug 4, 2016 | 07:14 PM
john 67's Avatar
look up a thread" lsa blower swap" its on page 5
Old Aug 6, 2016 | 01:14 PM
bigmandengo's Avatar
You could use the low mount truck compressor without a notch. Use holley's 21-3 accessory installation kit to space out the corvette accessories to a truck accessory alignment.
Old Aug 9, 2016 | 08:06 AM
samckitt's Avatar
I have vette accessories, and want to keep them, in stock location. And mount the AC compressor low on passenger side so it is in line with the rest of the vette accessories.
Old Aug 9, 2016 | 08:27 AM
ls1nova71's Avatar
Street and Performance makes one but it's not cheap.
Old Aug 9, 2016 | 07:56 PM
Old Geezer's Avatar
Be aware he's talking about the Sanden SD7 compressor...Some mounts use the 508...Different size compressor. The SD7 has a hi perf model, and removable port manifolds, that can be changed.
Old Aug 10, 2016 | 09:01 AM
jimmyg's Avatar
Dirty dingo makes a low mount sd7 bracket . Works mint . Will work with vette spacing . I used in my cutlass without a notch using Holley mounts . My build is in forced induction sec "Whipple build"
Old Aug 10, 2016 | 09:06 AM
jimmyg's Avatar
Attachment 547124
Old Aug 10, 2016 | 09:39 AM
samckitt's Avatar
Unless I am missing something, your build says you are using the holley vette style bracket but with truck spacing, that puts the AC belt farther out than true vette spacing would. So I would still need to notch front crossmember. I need to keep Vette belt where it is, so I can add LSA supercharger in front of it.
http://www.nookandtranny.com/_derive...xBalancers.gif
Old Aug 10, 2016 | 09:54 AM
1964SS's Avatar
The Dirty dingo kit works off the back rib set so it's not what you are looking for.
Old Aug 10, 2016 | 09:56 AM
samckitt's Avatar
If it clears using the back groves, then I can use it. But I don't think it will without notching front crossmember/motor mounts.
Old Aug 10, 2016 | 09:59 AM
1964SS's Avatar
It has multiple spacing setups on it by simply using different mounting holes so you might be able to space it out to the front.
Old Aug 10, 2016 | 10:48 AM
samckitt's Avatar
This Dirty Dingo bracket, we talking a lower AC mount bracket, or motor mounts?
Old Aug 10, 2016 | 11:06 AM
1964SS's Avatar
Lower passenger AC bracket for SD7 mini compressor
http://www.dirtydingo.com/shop/produ...oducts_id=1661
Old Aug 10, 2016 | 01:51 PM
samckitt's Avatar
Ah, thanks. At first I only saw the high mount one & their adjustable motor mounts.
Old Aug 10, 2016 | 07:06 PM
jimmyg's Avatar
With the sd7 and dirty dingo bracket there should be plenty of room with corvette spacing . The compresser is tiny
Old Aug 10, 2016 | 07:19 PM
jimmyg's Avatar
Looking for a low mount AC bracket that is inline with other accessories-photo314.jpg
