Ls3 with 4th Gen FBody accessories?
Old Aug 6, 2016 | 06:42 PM
crash41301's Avatar
Default Ls3 with 4th Gen FBody accessories?
Is this possible?
I am thinking about purchasing an LS3 crate engine, but need to retain my FBody accessories. Is there anything special about this setup that I need to get?
Old Aug 6, 2016 | 10:01 PM
Cheese Weasel's Avatar
AFAIK, there's no reason at all that you can't use a 4th-gen F-body FEAD with an LS3. I'm pretty sure that the mounting holes are all the same...
Old Aug 6, 2016 | 11:20 PM
MY_2K_Z's Avatar
You will need to use your fbody balancer for sure
Old Aug 7, 2016 | 12:27 PM
crash41301's Avatar
so the FBody balancer will fit onto the LS3 crank nose? Does it require modifications?
Old Aug 8, 2016 | 08:39 AM
chuckd71's Avatar
Externally there isn't anything special about an LS3. The reluctor wheel, knock sensor, cam sensor etc working with your current harness would be the issue.
Old Aug 9, 2016 | 07:51 PM
crash41301's Avatar
So I'm looking at basically a plug & play + rewiring + PCM here realistically, right?
Old Aug 9, 2016 | 11:46 PM
383z's Avatar
I was wondering the same thing. Thanks for asking OP.
Old Aug 11, 2016 | 01:10 PM
Project GatTagO's Avatar
I would not try to use whatever harness you have with your engine now. Sell that with the old engine as that would make it a more appealing package.
Go with the GMPP ECU and harness kit, plug-n-play for the LS3 (the have 3 different versions to match whichever LS3 you get...)
Andrew
