97 Jeep Wrangler
Doing the LS swap on this for a very good friend and now customer.
Dick Cepek rims, snorkel, and rockers guards installed by previous owner.
LED roof bar and LED bumper lights mounted but not wired by previous owner.
Pretty much all stock and entire tub coated by previous owner.
Speaker bar
Stock gauges, soon to go.
This where I am at,just need to mod my driver's side exhaust pipe to clear the skid plate,and on to finishing up the wiring
GM 12457705 5.3 LM7
Novak Adapt AX15 and 23 spline input gear
Advanced adapters GM to AX15 bellhousing
Chevrolet Performance 12571611 flywheel
Luk 04-049 clutch kit
ARP-330-2802 flywheel bolts
1-25222-X Griffin Pro Series 26x19 radiator
Autometer:
5381 dash panel (going to try to install new gauges in stock cluster panel)
880244 speedometer
880246 tachometer
880241 water temp
880240 oil pressure
880428 fuel level
880242 volt meter
9117 rpm signal adapter
LSEMTJ-KIT Daves Customs Umlimited engine mount kit
Hoping most of the parts will show up this week and get started this weekend.
Factory cluster disassembled.
New panel laid out and factory support trimmed.
Finished up the gauge cluster minus the speedo which will be coming soon hopefully.
This is the Autometer panel thats mounts in place of the factory cluster but I wanted this project to have a few custom touches that still kept a factory look. Also this panel seems to place the gauges more vertical rather than set back and laid back some like the factory cluster is.
Parts, parts and more parts!
I used the Novak bell housing and adapter for the AX-15. Slave was on the drivers side. Worked well.
I plowed snow for 2 years with this combo and then changed to a LS6/4L60E combo. Got tired of shifting.
The LS into a Wrangler is such a great swap. Mine has almost 10 years on the swap with zero troubles.
Way better than Christmas! These guys are on top of the game. One box contained everything ordered and packaged very well.
Nice tall shift lever and sweet new shift ****.
Out with the old
Old mounts cut off and frame rails cleaned up for new.
New motor and trans in. Transfer case input changed to 23 spline and noticed the input seal lip is completely gone. New seal installed, just waiting for the new flywheel so transmission and transfer case can be permanently installed. So far taking the measurements for the rear driveshaft, the aftermarket one that is in the Jeep will fit perfectly.
Transmission has planty of room. There is a ton of room to get to everything on these.
I used the basic street rod motor mount. Kind of a "L" bracket that I bolted to a welded mount on the frame rail. A rubber biscuit between that and engine motor mount. When I did the swap Novak didn't have their mounts yet.
I don't know about the ac compressor. I don't have ac. I can see if it fits. I think the upper control arm could be a problem. I have 2" lift on my TJ and the left upper control arm will hit the alternator, Camaro accessories under full compression. I added longer bump stops to prevent that.
