Post Your Pick-n-Pull Creativity
Old Oct 1, 2017 | 07:57 PM
  #41
Project GatTagO's Avatar
^^^Good stuff!
Andrew
Old Oct 1, 2017 | 08:01 PM
  #42
Michael Yount's Avatar
Gracias Andrew - inspired by your work!
Old Oct 1, 2017 | 08:30 PM
  #43
That's better work than any of mine! I wish I would have installed a little torque bar. My engine mounts have tweaked a little in the Cougar :-(
Old Oct 1, 2017 | 09:08 PM
  #44
Contemporary fwd motors are hung with mounts everywhere....I just view it as a third mount. Poly bushes - you can't even see it move when you rev it. All (most all) torque goes into the drivetrain rather than some of it into deforming rubber bits. Also easier on exhaust components.
Old Oct 1, 2017 | 09:37 PM
  #45
If you watch my in car videos at the drag strip, you can see how far the engine torques over on the launch!
Old Oct 1, 2017 | 09:42 PM
  #46
Where would a feller find that?
Old Oct 1, 2017 | 09:44 PM
  #47
Found it - jesus!
Old Oct 1, 2017 | 09:50 PM
  #48
Found it - jesus!
Lmao!
Old Oct 1, 2017 | 10:12 PM
  #49
My story - I did it to help fuel mileage.
Old Jun 2, 2019 | 08:00 PM
  #50
TipsyMcStagger's Avatar
BUMP! Because I know you guys are resourceful!
Old Jun 2, 2019 | 08:28 PM
  #51
This is a reminder that I need to go to the junkyard and just walk around. See what I see.
Old Jun 2, 2019 | 08:56 PM
  #52
B52bombardier1's Avatar
Hello,
Oh my. Seats for 20 bucks each out of a 95 Pontiac Grand Prix SE - fits my 70 El Camino perfectly. Great condition, my desired color and clean. Jeep Grand Cherokee steering box upgrade to give me better road feel and solve a leaky Pitman arm seal - 50 bucks.
New AC Delco Multec fuel injectors are about $140 each at the auto parts store but they are only ten bucks in the yards around here. A quick test for good impedance and then bring them home for internal pressure cleaning. Works great.
Random other good things not worth mentioning but yea, I sure like a good walk through the yards. I have a better steering wheel now than in the picture. And I'd like a tilt steering column for a 68-72 A-body but I'm not likely to find one of those in the junk yard.
Rick
Old Jun 4, 2019 | 08:27 PM
  #53
LS1 TJ's Avatar
So one of my best junk yard buys is not really cheap but much less than the aftermarket. I bought a pair of 2014 VW GTI bucket seats for my 68 C10 project. Paid $250 for the pair. Gray in color. A bit faded but otherwise perfect shape. The gray didn't work for me so I used fabric spray bomb to turn them black. Turned out great.
Old Jun 5, 2019 | 01:17 PM
  #54
Fast355's Avatar
I discovered a couple of things converting the 87 G20 to a DBW 6.0L. I used the pedal from a 2006 1500 5.7 Hemi Ram on the firewall bracket from a 2006 C3500 Chevy cab and chassis truck. Mounted the pedal in almost the exact position and angle as the stock G-van pedal. Also discovered that a later model GM OBD2 port physically fits onto the bracket for the OBD1 port after using a dremel to open up a slot that was already cast into the OBD2 port.
I have also discovered that Nissan Altima/Maxima coooling fans from many model years are almost a direct bolt on to a 28" wide older GM radiator core. They have 2 dual speed motors and move ALOT of air. The two speed motors are very simple to re-wire. 1 coil = low speed and 2 coils = high speed. Using the Nissan fan assembly saves me space in my aftermarket fuse box I use to convert my factory harness to stand alone. Only requires 2 relays to have dual 2 speed fans where the GM method requires 3 relays. This gives me the space to add a relay to invert the brake signal from the old style brake switches.
Old Jun 5, 2019 | 01:49 PM
  #55
Originally Posted by Fast355
I discovered a couple of things converting the 87 G20 to a DBW 6.0L. I used the pedal from a 2006 1500 5.7 Hemi Ram on the firewall bracket from a 2006 C3500 Chevy cab and chassis truck. Mounted the pedal in almost the exact position and angle as the stock G-van pedal...
Kudos!
Seems like such a random mix of parts. I never would have thought to go in that direction.
Old Jun 6, 2019 | 07:58 PM
  #56
JayinMI's Avatar
How's this for random? lol. I am building a 1989 S-10. It's getting a 6.0L LQ4 with 4L80E. Since I'm using a Trailblazer floor shifter, I wanted a tilt column, without the mount for the column shift. Stock I believe they only came this way in Syclones, Typhoons and Sonoma GT's. Kinda hard to find.
Found a floor shift tilt column out of a late 2nd gen Firebird at the JY, So, I used the lower shaft and lower S-10 tilt column (firewall mount is vehicle specific), paired with the top section of the Firebird tilt column (with no column shift mount). I removed the column shift arm from the engine compartment side inner tube to keep everything in position. The upper shaft is from an '09 Buick Lucerne, the lock plate and clock spring are from a '95 Grand prix with steering wheel controls and the steering wheel is a leather wrapped Cobalt LT wheel with steering wheel controls.
I got the idea for this from Camaro Rick on Youtube. He put a later C6 (?) steerring wheel on his '94 Camaro which uses a similar Saginaw (IIRC) column as my truck.
The only thing I still need to do, is make an adapter ring of sorts to go between the column and the steering wheel. There's about a 7/8" gap between the wheel and the column. I'll probably order some 1" think King Starboard or Expanded PVC to make it.
I plan to use an Arduino to interface with the steering wheel audio controls and possibly the cruise control buttons to send the correct signals to the PCM for the cruise to still work.
Installing it is a ways off. lol
Jay
Old Jun 8, 2019 | 07:25 AM
  #57
Nice work Jay.
