GM TPS Sensor starting at 100% while idle
I spoke with my tuner and he advised me to switch the wires in the TPS pigtail as they were backwards. Well I have one ground wire and then a 5V supply and then the signal wire. I went ahead and flipped the wires in the pigtail, but I am still getting the same read on HP tuners saying it is at 100% on the TPS.
I then checked the voltage on the pigtail, and I have 5V on both wires. As I open the throttle the voltage goes down. I thought that the voltage at idle should be close to 0 and as the throttle opens the voltage goes up, but I have the inverse. The voltage goes down as I open the throttle.
Can someone help me on this, I am at a lose here. I appreciate any help. Thanks guys.
I spoke with FAST this morning and they recommended me getting another TPS sensor, and see if that fixed the issue. The recommended part ACDelco 213-895 for this FAST 4150 Part#307603
I was able to look at an OEM TPS pigtail from my old harness, and right away I saw that the ground wire was in the incorrect position. So that little issue is done. I appreciate the help.
One question...I have not been able to take this thing for a test drive since I repinned the TPS. It seemed before the car was stuck in a "limp mode" in 2nd. It also would not shift. In your vast experience should I be getting shifts now and be able to go through all the gears? I am running the 4l80e. Thanks guys!
