Connector ID
Old Aug 28, 2016 | 01:07 AM
Smitty454's Avatar
Default Connector ID
Hey guys, I need some help IDing some connectors and wires. I have a couple wires labeled CEL and VSS. I already have a VSS wire going to the transmission I believe and Im not too sure about where this other VSS goes. I have no idea where the CEL goes to or what it stands for.
I also have these two in the pics below. They are both on the passenger side of the engine.
Old Aug 28, 2016 | 09:51 AM
ls1nova71's Avatar
VSS is Vehicle Speed Sensor, if you have it labled, then it most likely is coming from the PCM and is the wire for your speedometer. CEL is the Check Engine Light, it sends a ground to turn it on if theres a problem.
In your pics, the white one looks like the crank sensor, and plugs in behind the starter, its easy to miss. The purple one is the MAF sensor plug
Old Aug 28, 2016 | 10:14 AM
350SS's Avatar
I think the first pic might be the alternator since it is a 4 pin connector with two pins used?
Old Aug 28, 2016 | 10:19 AM
ls1nova71's Avatar
Good catch! Guess I should have made the picture bigger to get a better look at it....
Old Aug 28, 2016 | 10:34 PM
EFIHARNESS's Avatar
The first connector is 3 pin not 4 metric pack. so ckp or cam ?. what are the wire colors ? Second pict looks like maf.
Old Aug 29, 2016 | 10:12 AM
ls1nova71's Avatar
No, he's right, it's a 4 pin connector. You have to make it bigger to see it. It has 2 pins in the middle, my guess it they're going to be brown and gray.
Old Aug 29, 2016 | 12:33 PM
EFIHARNESS's Avatar
looking closer you are correct, 4 pin. the keying looks to be alt.
Old Aug 30, 2016 | 04:12 PM
Boy Scout's Avatar
Don't mean to hi-jack the thread, but just getting ready to start plugging in a harness on a 5.3. Any suggestions on a Youtube Video, or web link that can walk through the process ? (at least I will get the white alternator and MAF plug right !!)
Old Aug 30, 2016 | 07:01 PM
truckdoug's Avatar
well aside from the coils and injectors they really only plug into one thing
