LS1 and 4l60 swap into 36 chevy truck shift issues
After 11 years we got everything back together after tear down for paint and now having shift issues. Can someone steer me in the right direction. Trans shop says throwing codes P1637 Gen L terminal andp1638 Gen F terminal.
Everything shifted fine until we reinstalled everything after paint. Keep in mind this was over a couple of years.
Questions- I want to go back over my wiring. I am running a 1 wire alternator. Does the ECM need to see this anywhere? For now I have the alt connected direct to battery for charging. Volt meter in dash is wired so it just picks up on 12 volt current from the fuse panel. Is this OK?
I am running a street and performance harness. I am thinking it was pretty much plug and play wit the exception of the orange power wire and ground. Any more anyone can think of here I might check?
It is drive by wire. 2002 corvette with torque tube and 4l60e. It is getting power to the 11 pin on the trans connection.
