swap done, but has no power
I have completed my 5.3 aluminum block swap w t56 into a 1986 volvo 240. the engine is stock, and there are no vacuum leaks. there is no cel, but i have only driven it about a mile or less. i have a psi harness, ans computer. in neutral, the car does not really want to rev, and in first it barely even accelerates. i am going to work on it tomorrow, and any help or suggestions as to where i shoukd start my search are welcome. thanks.
I scanned, and it had no codes. Maybe I will just drive it a little more, and see if any codes pop up. I am planning to check fuel pressure at the rail.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
OK, being a bit more serious, fuel pressure at the rail seems like a good place to start, but any more info you could provide would be helpful. Could be a fueling issue, or maybe an exhaust blockage (I had the internals of a stock catalytic converter come apart on me once, showed similar symptoms). Good luck.
Thanks. i know i am not providing a ton of info, as i havent really gotten to troubleshoot much yet. while i can not rule anything out 100% the exhaust is new from the block back, with no cats. So it is not likely an exhaust issue. I hope to fix it tomoorrow. If i am unabke to, i will at least have some more info.
