GEN V Swap info!
1. Fuel pressure requirements- So far the standard fuel pressure of around 57 psi works great. Fuel trims are dead on. Just make sure you have a pump that will support the engines power. I have tested using the Fuel Pressure control modules with great success. If using the FPCM use regulator for a non pwm pump. If using a PWM pump then do not use a regulator. Basically if you can monitor fuel pressure after the pump monitor it for any pressure drop. If no pressure drop then you are supplying the engine with enough fuel. Running a pump at 74 psi is not necessary at all.
2. Programming- I used hptuners to delete vats and any DTC codes that showed up. Get the matching ECU and BCM from the donor vehicle. You will have issues programming a new OS and VIN if you do not. (BCM needed for transmission tap shift control and the brake pedal position sensor if used) This ECU has so many complex tables be careful of any changes you do. If you use GM SPS service you can not program off vehicle. You will need the ECU, TCU, and BCM at least to program. You most likely will not be able to change the VIN but it will program the new OS. The 2016 model year ECU is NOT swap friendly.
3. Transmissions- I have only used the matching 6l80e and 8l90e transmissions. Everything works including tap shift and power modes. The new transmissions really make this an awesome combo. Early transmissions can be used as well along with manual transmissions. Be aware the flexplate and flywheel have a different bolt pattern.
4. Accessory Drive- We just added a power steering pump on a truck layout. Holley, ICT billet, and dirty dingo offer different drive solutions. If using DOD/AFM you will need to keep the vacuum pump.
5. Wiring Harness- I modded the harness myself and is not too hard. Please recommend any companies that currently make custom harnesses. Having it modded will be by far the cheapest and quickest solution.
6. Fuel pump signal- This is now can bus driven. For proper control us a fuel pressure control module. (UPDATE)!!!You can control the fuel pump via a relay. Connector E92 X1 with the blue face use pin 32 (grey wire) This is a positive turn on signal for your relay. So pin 86 use this wire. Pin 85 will be ground. 30 and 87 are power in and out to fuel pump.
7. Fan Control- You can use PWM only on a factory ecu. Discrete does not work. I am using PWM with awesome results. It controls the fan speed based on A/C pressure and ECT. GM performance parts ecu uses a standard on/off signal. Update!! There is a trick to make a relay work to control a single speed fan. PM me for how to do this.
8. Limp mode issues- I had no throttle without connecting the transmission computer up. If not using the matching transmission that came with the engine you will need to find a manual transmission tune. (If anyone finds a solution please post. GM's swap harness and ECU will not have this issue.
9. DOD/AFM- It is highly active with the stock tune. At 65 mph it can be in 4 cylinder mode. Cruising around town it will kick in all the time. Its loud and annoying to be honest. GM tuned the exhaust so you do not hear the change. For now I have it only working on steady cruises.
10. Engine Mounts- It is very important to use factory mounts if retaining AFM/DOD function. The mounts help absorb the extra vibrations. Please list any companies that make conversion mounts. I had a set made for the Jeep JK wrangler.
11. Gauges- Best bet is to use can bus driven gauges from dakota digital or speed hut. There is no VSS signal or tach signal from the ecu to drive a gauge
The new Holley Gen V oil pan is going to be a key component for putting these engines into many classic GM chassis.
Andrew
Tricky installing them with the electric powersteering setup that comes stock. We used a ICT billet bracket kit with a corvetter power steering pump. ALso used there engine mounting brackets but had to cut the driver sided for the vaccum pump. We used a SPEARTECH wiring harness. No issues and plugged right up.
Currently I am running 2014 engine operating system and 2015 transmission operating system and so far this is working.
