New Holley Accessory Drive Systems Coming Soon
Old 10-09-2016, 10:22 AM
user 4737373's Avatar
Originally Posted by Pocket
Any more info on that low mount AC bracket? Is is for sure only compatible with truck spacing?
Does the low mount alt on corvette spacing require clearancing of the block like other low mount kits?
It can be installed at at the Corvette, F-body or truck offsets; no grinding/relieving of the block is necessary.
Old 10-10-2016, 10:38 AM
Pocket's Avatar
Thats great
Any word on the low mount AC?
Old 10-10-2016, 12:32 PM
Thats great
I'm assuming you are referring to a release date. If so, I've not heard anything concrete at this point.
Old 10-10-2016, 03:29 PM
Pocket's Avatar
No, whether it fits all LSx spacings or is truck specific
Update:
Did some research of my own
Turns of the accessory drive is only available for Fbody and truck spacing (middle and long by their terminology)
The AC bracket will fit all three belt spacing systems
Corvette and LSA guys can now have low mount aftermarket AC but will have to use the older style Holley bracket (First post, second pic) or a similar OEM piece
Old 10-10-2016, 03:51 PM
I think you missed my previous post #21.
Old 10-10-2016, 03:52 PM
Jimbo1367's Avatar
Prolly just the truck being it's VVT. I would imagine they. Will offer the required spacers (short: mid. Or long) just like their LS FEAD
Old 10-10-2016, 07:02 PM
So we're all on the same page, the new Holley LS low-mount A/C compressor bracket will install at the Corvette, F-body and truck offsets; all parts/adapters to accomplish that will be included in the kit with no extra spacer kits to buy in this time around.
Old 10-11-2016, 03:09 AM
Jimbo1367's Avatar
Glad you cleared it up. So does Holley have a release date yet?
Old 10-11-2016, 07:53 AM
I've not heard anything regarding a release date yet, but I know the project is beyond the design phase and into the tooling phase.
Old 10-11-2016, 11:14 AM
Jimbo1367's Avatar
That's a good sign.
Old 10-13-2016, 12:46 PM
Corey R.'s Avatar
Hi Todd -
Will this setup work with Non-AC 67-69 Camaros? I have only seen mention of the possible AC compressor fitment wit the truck spacing.
If the answer is yes, which spacing style would work?
Old 10-13-2016, 01:51 PM
  #32
Originally Posted by Corey R.
Hi Todd -
I've not done any specific test fitting on a 1st-gen F-body at this time, but from what I know about the fitment of the stock 4th-gen F-body FEAD, it should install at the truck offset with no issue and at the F-body offset by notching the subframe under/behind the alternator. I don't suspect the low-mount A/C compressor set-up will be installable in the 1st-gen F-body application at any offset when used with the Hooker 1st-gen LS swap engine brackets.
Old 03-10-2017, 04:21 PM
  #33
TxFireman1972's Avatar
Any release date yet?
Old 03-10-2017, 04:47 PM
  #34
I don't possess any release date info due to them being designed by another group of engineers. Here's the images you PM'd me about showing the set-up mocked up on the Fox body swap vehicle. The SD7B10 is the only compressor that will fit in the bracket and it kisses the factory anti-sway bar when used with the coming Hooker Fox-body engine swap mounting brackets, so you will have to space the bar down for clearance. It is shown installed at the Corvette spacing in these images.
Old 03-10-2017, 08:07 PM
  #35
WFO_SS's Avatar
released? i don't know. but they've recently put pricing on some of the stuff:
https://holley.com/products/ls_power...y/parts/20-159
Old 03-10-2017, 08:37 PM
  #36
Yeah they have pricing but it shows "pre-order" with only an estimated ship date. Been there done that. That means they don't know lol
Old 03-10-2017, 09:07 PM
  #37
CapriceLS's Avatar
Yea I purchased the pan the beginning of January and been waiting since. Really sucks because that's the only thing that's keeping me from dropping the motor in my swap. Seems like every time I log in the date is pushed back 2-3 days.
Old 03-10-2017, 09:17 PM
  #38
Received 3,153 Likes on 2,460 Posts
New post not showing.
edit- There it is!
Old 03-13-2017, 02:27 AM
  #39
Jimbo1367's Avatar
Toddoky,
that lowmount AC looks great., (tugging on your sleeve) any info on the GEn V oilpan yet? LOL
Old 03-30-2017, 08:12 AM
  #40
Russt's Avatar
I'm also waiting on the Gen V oil pan, toddoky seems to be very quiet on any release date. I'm hoping he can update us?
Quick Reply: New Holley Accessory Drive Systems Coming Soon
