Andy's 66 Caprice LS Conversion
Old Oct 15, 2016 | 06:13 AM
kwhizz's Avatar
Looks like Photobucket is back to normal.........So.....Here are some update pic's....Picked up the drive shaft today and got it installed....
Made a mount for the GM fuse panel and got it mounted....
Got the mounting plate for the ECM and TCM..........Then installed the unit in the car.....
Old Oct 15, 2016 | 06:28 AM
kwhizz's Avatar
Got the front drive belt installed.........With this set-up a 99.5" belt fits perfectly.......
Got all the A/C hoses made and installed.......
Wiring is starting to be put in place
Radiator is in temporarily.......Need to modify the mounting holes........Keith's bolted right in.......Hummm.....
Mocking up the air intake system...........Getting closer
Starting to look like a completed project.........
Going for the exhaust system next Thursday........Don't know if I will have it wired and running by then, but, if not it will be flatbedded............
Old Oct 15, 2016 | 06:53 AM
alocker's Avatar
The radiator spacer looks like it's in upside down. It should follow the contour of the core support on top. It will still bolt the the core support but then the radiator holes might be off because they are flopped.
Edit, now I know it is. The small hole in the center by the cap is the drain hole.
Old Oct 15, 2016 | 09:01 AM
gofastwclass's Avatar
Originally Posted by ls1nova71
And another swap gets started....... I'll check back in tomorrow night to see the final product!
We all can't move as fast as you two! Speaking of... I need to see some pictures of the latest... hint, hint. I can even come over and help throw wrenches. Hahaha!
Old Oct 15, 2016 | 12:12 PM
kwhizz's Avatar
Just about finished under the car.......By moving the trans cross member back a couple inches, it now made the E-Brake cable way too long.........had to cut it to suit and make a new stop feature for locking the cable........worked out perfectly.....
The transmission cooler lines are in and installed......Just needs trans fluid......
Also got the heater valve and lines finished up also......
Old Oct 15, 2016 | 12:16 PM
kwhizz's Avatar
Checked the spacer and it has the same hole in the bottom.......?????
Old Oct 16, 2016 | 07:26 AM
alocker's Avatar
I apologize I forgot the 65-66 spacers had the same curve top and bottom unlike the 67-68 ones. That might be a variation Dewitt's isn't familiar with. Online they all look the same but I know they are not because I bought a 66 spacer and it fit my car but was not correct.
Old Oct 16, 2016 | 07:33 AM
alocker's Avatar
Old Oct 17, 2016 | 08:05 PM
kwhizz's Avatar
Upadate.........Got Lucky and found a upper Radiator hose that fit perfectly......Got the Air Intake set-up completed with fittings for the PCV system and MAF sensor.........and Got the power steering hose made and installed, along with the reservoir.......started on getting the fan relay's wired and installed......Moving along..........
Old Oct 18, 2016 | 03:33 AM
Russ.W.'s Avatar
Looking great.
Do you have a link to which air intake pipe etc you get?
Old Oct 18, 2016 | 06:06 AM
kwhizz's Avatar
Originally Posted by Russ.W.
Looking great.
Here you go ..............
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Oct 18, 2016 | 08:42 AM
  #32
Russ.W.'s Avatar
Cool. So looking at everything else in the images, you're just piecing together pieces from generic kits as apposed to a '66 B-Body specific kit?
That makes sense, and knowing the pipe's bend angle makes things much simpler. Cheers.
Old Oct 18, 2016 | 07:14 PM
  #33
kwhizz's Avatar
Exactly !!!!!!
Old Oct 19, 2016 | 07:21 PM
  #34
kwhizz's Avatar
Got the radiator hoses completed......got the steam port line in......Filled the system with coolant....... (No leaks.....That's a good thing)....LOL......got the PCV system installed.....Got the wiring roughed in for the Fan Relays.....(Thanks Donnie)...The car is being flat bedded to the exhaust shop for the system to be installed tomorrow........The Dakota Digital Cluster and modules will be arriving tomorrow also........After the exhaust, I need to spend about a hour finishing the wiring under the hood and about a day getting the Dakota stuff installed..........Getting real close...
Old Oct 20, 2016 | 03:48 AM
  #35
Jimbo1367's Avatar
Ken,
You make this look too easy. LOL
Old Oct 20, 2016 | 05:46 AM
  #36
kwhizz's Avatar
Practice makes Perfect......LOL
Old Oct 20, 2016 | 05:57 AM
  #37
TomM's Avatar
Is it just me or does that motor look like it should have been in there from the factory?
T,
Old Oct 20, 2016 | 07:43 AM
  #38
lizeec's Avatar
The way Ken does his conversions, they do look like they came from the factory that way!
Old Oct 20, 2016 | 10:51 AM
  #39
showdog75's Avatar
Do yourselfa favor and check out TomM's work. I bet Tom and Kwhizz send each other Christmas cards.
Old Oct 20, 2016 | 06:35 PM
  #40
kwhizz's Avatar
Exhaust is in and the car is back........Another great job by Dave's Mufflers in Kenosha.......James works his magic again
