Andy's 66 Caprice LS Conversion
Old Oct 3, 2016 | 08:52 PM
kwhizz's Avatar
Default Andy's 66 Caprice LS Conversion
I met Andy at the Elkhorn Swap meet a year ago and we were talking about the LS swap into the 66 Impala Convert.....We got hooked up again in early summer this year and were talking about the Ackermann issues these "B" body cars have........Ended up Andy had the GM Service Bulletin from 1966 resolving these issues .........Anyhow......Here we go again........LOL......
Staring point is a pretty nice rust free Caprice.........Putting in a LS3 480 HP/4L70E GM connect and cruise set-up just like we put in Gary and Keith's cars.....
Old Oct 3, 2016 | 09:16 PM
ls1nova71's Avatar
And another swap gets started....... I'll check back in tomorrow night to see the final product!
Old Oct 3, 2016 | 09:17 PM
kwhizz's Avatar
The trans tunnel is tight in these cars and getting the cooling lines out to the radiator is simplified by getting rid of the factory fittings and going aftermarket with trans rated rubber hose......
The next issue is the Holley 302-1 pan contacts the front cross member.......I made up some engine mount adaptor plates to raise the engine a 1/2" to resolve that issue...............
Got the starter and converter bolted in.......Then the wiring........LOL.......Probably get it in the car tomorrow
Old Oct 4, 2016 | 02:02 AM
Russ.W.'s Avatar
... and another one! haha. Nice.
Old Oct 4, 2016 | 04:47 AM
alocker's Avatar
Clean Caprice. Looks like he did all the hard stuff like A/C already.
2 questions for you.
1. How do you guys all like the Classic Auto Air?
2. Are you making money from these swaps? No need for details I'm just curious if your just nuts and do them for free or if its a nice supplement.
Old Oct 4, 2016 | 05:38 AM
TomM's Avatar
Are you done yet....LOL...
T,
Old Oct 4, 2016 | 06:22 AM
kwhizz's Avatar
The Classic system lines up with the factory Defroster system..........
And............Yes I am Nuts !!!!!
Old Oct 4, 2016 | 08:53 AM
Hart_Rod's Avatar
Sweet build!
Old Oct 4, 2016 | 09:09 PM
Project GatTagO's Avatar
In for updates.
Andrew
Old Oct 5, 2016 | 05:24 AM
alocker's Avatar
I thought so
So the CAA system is mediocre?
When are we going to have an LS Chevy Full Size Meet? Great Lakes Dragaway???
Old Oct 6, 2016 | 12:09 AM
kwhizz's Avatar
Got the Fuel system pretty much completed today......Fuel Pump fit and installed........Fuel Level Sender fit and installed........Filter Regulator installed and lines made........Then got the Tank installed.........Wiring for the Pump and the Dakota Digital fuel gauge installed also........Moving along..........
Old Oct 10, 2016 | 08:32 PM
kwhizz's Avatar
Well.......Dave and Greg came over today and helped out putting the engine in the car......Took all of about 5 minutes.....Now the fun starts......Andy cut off the trans mounts from the frame......got the cross member installed and tack welded the mounts back in.......Brent will do the final welding tomorrow....(he's a real welder....LOL).......On with the assembly.....
Old Oct 10, 2016 | 08:36 PM
kwhizz's Avatar
More.................
Old Oct 11, 2016 | 04:01 PM
kwhizz's Avatar
The leg is now getting back to normal and things are starting to move again.......Didn't say anything yesterday, but if you look at the picture below, you will see the front Chinese header bolt is missing......I was using a air ratchet to draw them in and the bolt as it was running down just snapped off.........Talk about getting pissed........That was a signal to go take a Nap.......It was in an accessible position, but getting the drill started in the center of the bolt to drill it out in an area that wasn't the best to see what you were doing.........went to the shop today and thought it thru....Made a bushing to go into the header flange with the metric tap drill size in it.......put it in and it centered the drill perfectly.....drilled thru the bolt and retapped the hole.......problem solved......
Now that my Blood Pressure was down to normal, I went on and finished getting the Front Drive set-up installed........Headers installed on both sides and got the frame trans cross member mounts all welded in.......Time for a nap again (a good one this time)
Old Oct 12, 2016 | 02:44 AM
Jimbo1367's Avatar
Looking good KEn. I bet you're getting real quick at these. LOL
Old Oct 12, 2016 | 06:51 AM
TomM's Avatar
Man that is a clean install.....looking good as usual....
Clever fix on the bolt thing....
T,
Old Oct 12, 2016 | 07:19 AM
Ken,
Why are you not using the stock flanged bolts for the headers?
Andrew
Old Oct 13, 2016 | 07:06 AM
kwhizz's Avatar
Went and picked up a yoke for the transmission and got all the dimensions for the Driveshaft that is being made at Don's Automotive in Kenosha.......Also got the fuel line and Filter installed and completed.......then I installed the column shift linkage........moving along......Driveshaft should be finished today
Old Oct 13, 2016 | 07:16 PM
showdog75's Avatar
I wish you were my neighbor. I'd handle all your welding needs(better welder than the one you already have!!!)
Old Oct 14, 2016 | 02:04 AM
Jimbo1367's Avatar
Don't we all. LOL> Keep up the great work Ken !!!
