5.3 lm7 build
Old Oct 6, 2016 | 07:46 AM
Ben Ricci's Avatar
Default 5.3 lm7 build
I've got a 1985 s10 blazer 2 dr, and it already been swapped once to a tbi 4.3 and I'm really wanting to do the 5.3 swap, I have the engine. Trying to get a harness and pcm as of now, I'm gonna be using the 700r4 trans and I'd be nice to get some tips on what to do with fuel system, possible help with diy standalone harness, and just general stuff thanks in advance
That's her
Old Oct 6, 2016 | 09:00 AM
JoeNova's Avatar
Restricted User
www.lt1swap.com for Harness info. Everything you need to convert a stock truck harness to stand-alone is there.
You'll need a fuel pump/regulator swap.
Old Oct 6, 2016 | 09:36 AM
Ben Ricci's Avatar
What's the best choice in fuel pump, I was looking at a high pressure 190 and 255lph is that to much? Or not enough?
Old Oct 6, 2016 | 10:22 AM
JoeNova's Avatar
Restricted User
Go with the 255 lph.
Old Oct 6, 2016 | 10:25 AM
Ben Ricci's Avatar
High pressure 255 or standard 255
Old Oct 6, 2016 | 10:26 AM
JoeNova's Avatar
Restricted User
Might as well go with the high pressure.
You'll also need a regulator since the LS engines run at 58 PSI of fuel pressure.
Old Oct 6, 2016 | 11:38 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Going to have to follow along with this one. I have a serious soft spot for those trucks. I have had 3 just like it. All black, 2 door, 2wd. Can't wait to see how this one turns out
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Oct 6, 2016 | 11:44 AM
Ben Ricci's Avatar
Thanks, what's a decent fpr?
Old Oct 6, 2016 | 11:46 AM
Ben Ricci's Avatar
Thanks, I actually sold it once and I somehow but some stroke of luck found it and bought it back just recently lol... but I'm putting it up in two weeks to start the tear down!
Old Oct 6, 2016 | 12:27 PM
JoeNova's Avatar
Restricted User
Depends. If you run a stock truck intake with return style rails, then use the regulator mounted on the rails, it works great.
Otherwise, the corvette regulator also works as a filter, and has the return built into it so you can just run a line right back into the tank.
https://www.summitracing.com/parts/wix-33737
Old Oct 6, 2016 | 12:38 PM
Ben Ricci's Avatar
Thanks, I'll keep this updated as much as possible... I'll be running the truck intake, what one is a better choice the 700r4 (my truck has) and 4l60e? And why?
Old Oct 6, 2016 | 01:14 PM
JoeNova's Avatar
Restricted User
Just run the 700r4.
The 60e is a great trans and works very well with the stock PCM, but its basically just an electronic version of what you already have.
Old Oct 6, 2016 | 06:44 PM
Ben Ricci's Avatar
Thanks, like I said I'll keep this updated as much as possible!!!
This is the truck now how it sits! Much more to come!!
Old Oct 6, 2016 | 08:39 PM
sowbelle's Avatar
I run a 700r4 in my 68 truck. I have had very good results with it. BUT, you will need a TV cable and bracket for that cable. GMoverdrives.com has the cable and bracket as a
kit. In my opinion, it is a little pricey, but it works and is the only kit that I have been able to find for this application. You cannot use this trans with a DBW throttle body and have any trans longevity. The 700 MUST have a TV cable to live properly. Please read LIVE PROPERLY.
But get a converter to match the engine and have fun. I love these cars also.
Old Oct 7, 2016 | 07:20 AM
JoeNova's Avatar
Restricted User
We usually drill a hole in the throttle cam, put a bolt in it and attach the TV cable. Works pretty good.
A 4L60e is a damn good trans, but it'll have to be wired in and tuned.
Old Oct 7, 2016 | 08:30 AM
Ben Ricci's Avatar
Thank you, any links possibly?
