LS oil pan gasket change while in car
Looking to see if anyone has changed the oil pan gasket while the motor is still in the car. I have a 82 MonteCarlo and I have a very lite oil leak. Honestly, its so small I could just ignore it but the perfectionist in me won't let me do that lol. I haven't seen a drop on the ground yet but I do see some oil film on the back of the pan near the bottom and on the two long oil pan bolts. I pulled the Trans last year and it's not coming from the rear main seal.
No rivets in this pan. I built the motor from scratch. Just want to know if I would have to raise the motor and remove the oil pan pickup tube to get the pan out.
Ok. It's not leaking bad at all so if I have to raise the motor and stuff I'll leave it along. If it was a constant annoying drip or spot on the garage floor then I would change it no questions asked.
Question is... how close is the pan to the Cross member.?. if it is close, You most likely will have to raise it some to get the pan to clear the windage tray and pickup tube for you to remove it
BC
BC
I tried this on my Nova. I dropped the pan 4" or so and the gasket isn't coming out. The pickup tube sits very close to the bottom of the pan, so you basically need to be able to drop the pan enough to actually remove it, or at least pull the pickup tube out of the baffling.
I would drop the pan an inch or so, and run a bead of Ultra Black RTV around the gasket and re-install.
Are you 100% sure it is the pan and not leaking down there from somewhere else?
I thought mine was leaking at one point and it was just a loose oil pressure sensor on the top of the motor. Rub your hand around and check for wet spots, LOL.
