Need transmission recommendations
Old Nov 16, 2016 | 09:32 PM
LS_C10's Avatar
Default Need transmission recommendations
Recently got a 85 c10 with a ls1 in it. the motor runs perfectly, aside from the previous owners "custom" wiring. He had stated that you have to go through every gear manually but it has a 4L80E transmission. And finally driving it I have come to that it does not have reverse or overdrive in the gears. Personally I don't care if it has reverse or not but I'd like to have it as my daily driver, I'm thinking of changing out the tranny, and if I do should I just go for the same type? Or go with a different type? Please sent some ideas my way!
Old Nov 16, 2016 | 10:18 PM
.boB's Avatar
It all depends on what your goals are, and what the rest of the truck is like. It's a 4 speed OD, so if the gears match your use, there's no reason not to use it. Swapping like for like is a lot easier than adapting something new.
But, the question is, why doesn't the current transmission work correctly? The 4L80E is an electronically controlled unit. And the truck has a "custom" wiring harness. Is the wiring correct to control the unit? Maybe that's why there's no OD or revers, and why it won't shift on it's own. If you simply swap in a new transmission, you could be right back where you started, except tired and poorer.
I'd spend some time sorting out the wiring and trans controls before doing anything else.
http://www.novak-adapt.com/knowledge...utomatic/4l80e
Old Nov 16, 2016 | 10:29 PM
LS_C10's Avatar
See I'm not sure why there is no OD or reverse, kind of why I came here lol. I had to install a Lokar floor shifter for it and when I went to drive it was only missing OD and reverse, when the shifter is in the location of the gear the truck just revs like its in neutral.
Old Nov 17, 2016 | 05:36 AM
jimmyg's Avatar
Trans is probably wired wrong . You also have to make sure the program for that trans is in ecm. Is truck carb or Efi? It might not even have an ecm. You might just need a trans controller
Old Nov 17, 2016 | 05:01 PM
LS_C10's Avatar
The truck is Fuel injected
Old Nov 17, 2016 | 08:45 PM
squarles67's Avatar
4L80 is a great trans, troubleshoot the one you have and figure out what the problem is. There is a transmission sub-forum here as well.
Old Nov 18, 2016 | 05:22 AM
jimmyg's Avatar
There is tons of wiring diagrams online for the 4l80.. if you can't fig it out, you could always get a standalone trans controller. Us shift makes a nice one.
Old Nov 18, 2016 | 06:49 AM
ijimmy's Avatar
you need a controller , it dictates line pressure , which is critical to all transmissions
