Outlaw 996 Porsche build
Old 02-28-2017 | 05:16 AM
  #121
dcd215's Avatar
Never put a meter on it and I have it apart right now -injector issue .I am guessing 14.4 or so .Did you put a meter on the alternator light terminal to make sure it is generating a voltage ?
Old 02-28-2017 | 06:14 PM
  #122
Outlaw 911's Avatar
Mine is apart now also, but it was showing good charging voltage on the dash volt meter. I did check the wire from the alt back when i first started it but i don't remember what voltage it was putting out. I will have to do more testing when i have the water pump back on. If the porsche is looking for 12v then testing the ls alt wire will tell the tale.
Thanks
Old 02-28-2017 | 06:36 PM
  #123
dcd215's Avatar
In the interim -you could test the light with a 12 volt lead
Old 02-28-2017 | 06:47 PM
  #124
ca12los's Avatar
Outlaw,
​​​​​​​while you look for the voltage, ground the blue wire with Key on and all your warning lights will turn on. Test that to make sure the wire is good.
Old 03-08-2017 | 08:02 PM
  #125
Outlaw 911's Avatar
Well i removed the water pump adapters and the pipe/hoses running to them. Nothing i tried to stop them leaking worked so in the trash they went.
Wanted to run the LS2 pump but it interfered with my intake tube so I ordered a LS3 pump.
So far it is working and looking much better and no leaks.
Ran the stock tensioner and mounted the idler on the other head.
Yep a little close to the tube but thats how it has to be.
I still need to finish tidying up the balzecut but zip ties will take care of that.
Fingers crossed test drive soon........
Old 03-09-2017 | 07:36 PM
  #126
Outlaw 911's Avatar
Backed it out of the shop at 730am and let it run for about 15min and no leaks! Stayed about 180/185 deg. for that time and it was then that I decided it was time for the first drive. Only went about 2mi but it went smooth,stayed cool and the power is great. Im pretty sure it would smoke my old z06.
Next its time for a/c, it going to get hot real soon..
Old 03-10-2017 | 09:39 AM
  #127
4LUX's Avatar
congrats!!! I will be doing the same thing next weekend. The last thing to do is bleed the clutch slave/brake system, I ordered a Motive Power Bleeder. And it will not be in until Monday.
Old 03-10-2017 | 05:39 PM
  #128
Outlaw 911's Avatar
Thanks 4lux!
The ls2 moves this car so easy, i cant imagine it with a ls3 480 or 525! It would be a beast!
I cant wait till i get it plated.
Old 03-10-2017 | 06:05 PM
  #129
AAIIIC's Avatar
Congrats on the first drive!
Old 03-10-2017 | 06:37 PM
  #130
blownc2's Avatar
Originally Posted by Outlaw 911
Thanks 4lux!
I put the LS3 525 in mine. Its fast, but I thought it would feel faster. It still has stock exhaust manifolds and the factory tune. Hoping I'll pick up some power when it goes to the tuner.
Old 03-13-2017 | 08:32 AM
  #131
Outlaw 911's Avatar
Blownc2 ,how is the trans holding up with that much power/torque?
Old 03-13-2017 | 06:07 PM
  #132
Outlaw 911's Avatar
Got my rear swaybar mounts made today,nothing fancy just some 3/8 6061 to drop it down.
Old 03-14-2017 | 08:50 AM
  #133
blownc2's Avatar
Hey Outlaw. It's my track car and only caught the last for days of the season. So far so good. I'm wondering the same myself. I hope it holds up.
Old 03-14-2017 | 02:21 PM
  #134
hayabusa's Avatar
Default o2 sensor
Are you running both the chevy o2 sensors and the porsche's?
Old 03-14-2017 | 06:23 PM
  #135
Outlaw 911's Avatar
Yep for now im trying to keep the porsche ecu happy .
Old 03-17-2017 | 06:55 PM
  #136
Outlaw 911's Avatar
My Dirty Dingo a/c mounts and compressor showed up yesterday. Got it mounted today and got my list of hose and fittings made up.
Get that stuff ordered asap.....
Lousy cell pics....
Running out of real estate FAST......
Old 03-17-2017 | 09:13 PM
  #137
shanghai_todd's Avatar
+1 for Dirty Dingo products.. My A/C fitting block showed up this week with the headers and probably would have been smart if I had these before making my brackets. I ran into some clearance issues but nothing that a little re-engineering and cutting can't resolve.
Are you planning on running a catch can?
Agree, space starting running out quick and everything gets a little tighter towards the end but still more simplified than dealing with anything on a 911 engine. Simply drop the bumper and all the accessories are right there with easy access.
Old 03-18-2017 | 05:49 PM
  #138
Outlaw 911's Avatar
Todd, as of now no catch can i will wait and see if it needs one.
The DD brackets fit good but i needed some clearance with a water hose so I cut off the square nub on the block and mounted the top bracket flat.
That ment i needed a new belt but i got that today. I have to say that the tensioner seems a lil weak for a belt with the load of an a/c compressor on it.
Old 03-18-2017 | 08:19 PM
  #139
Regarding wiring and gauges does the 996 use the same 4 plug sensor that has the oil temp and oil level (6-9" rod)? Temp sensor wiring is pretty straight forward but was curious what signal or value the factory ECU is looking for to bypass the error message.
Old 03-19-2017 | 09:31 AM
  #140
Outlaw 911's Avatar
Posted what i know in your thread.......
Quick Reply: Outlaw 996 Porsche build
