T56 in 69 Camaro
Old Dec 15, 2016 | 07:19 PM
Flamed350's Avatar
Default T56 in 69 Camaro
Starting in two weeks ill be putting a 6.0 and T56 in my 69 camaro, im wondering what shifter people use so that i could still use the stock console?? Thanks in advance
Old Dec 15, 2016 | 07:49 PM
user 4737373's Avatar
If you're referring to a 4th-gen F-body T56, the shifter you'll need to accomplish that will depend on the specific engine mounts you use and the fore/aft engine position they provide.
Old Dec 15, 2016 | 08:17 PM
Flamed350's Avatar
Thanks for the reply. Yes its a 4th gen T56 and engine mounts i bought will sit the engine forward 1 inch.
Old Dec 15, 2016 | 08:30 PM
The use of forward biased mounts will have a positive effect towards being able to use your stock console. You will need to use a forward offset shifter, even with using 1" forward biased engine mounts. McLeod offers some nice offset shifters you may want to look into.
Old Dec 16, 2016 | 07:30 PM
Flamed350's Avatar
Thanks again. I had read about them as well as the sst or the blackjack. Wasnt for sure if there was something else out there or those three.
Old Dec 18, 2016 | 04:10 PM
Flamed350's Avatar
Any other ideas?
Old Dec 24, 2016 | 04:07 PM
Beeler422's Avatar
Back in the staging lane
I'm using energy suspension mounts with b&m ripper shifter and the stock console.
Old Dec 27, 2016 | 07:51 PM
Aston Tibs's Avatar
I couldn't get my stock console to work on my build. I didn't want to use the offset shifter since the stick would move up and down as well as back and forth when you use the offset. I couldn't slide my console back either as I have aftermarket seats that are already wider than stock. I thought about using the forward inspection plate as they have a kit where you can put your shifter there, but it moved it too far forward. I ended up going with a UMI Short Stick that I heated and bent to get the right vertical angle. I am currently building a console using 1/8 plywood and 2nd gen Camaro trim pieces. I will cover the plywood with vinyl/leather when done for a finished look. I should start posting those pictures on my build thread.
Old Dec 29, 2016 | 09:07 AM
Flamed350's Avatar
Good info guys. Thanks for the help.
