Which DBW pedal with Holley dominator?
I'm installing a gen III LQ4 with an LS2 intake and GTO throttle body in my 65 nova. Using a Terminator mpfi 550-623 and need to know which pedal assembly will work
Thanks
Mike
When using the Dominator ECU you need to stick with the parts that are in the manual. Although, some different parts will work as well. For instance, I am using the gen IV truck throttle bodies on my Cougar and they work perfectly. This is the same TB that is on a lot of the later Gen IV cars, like LS3 Camaros and on the LSA engines.
Andrew
http://www.rockauto.com/en/moreinfo....440301&jsn=584
http://www.rockauto.com/en/moreinfo....441009&jsn=634
Andrew
