VSS for PCM when using a TH350
Old Jan 19, 2017 | 11:40 AM
aggie91's Avatar
Default VSS for PCM when using a TH350
I am planning to run a TH350 behind my LM7 in my swap, mainly because I have it and it is ready to go.
I understand that the PCM needs a speed signal usually from the VSS in the transmission. Since the TH350 does not have a VSS, HOW do I get that signal to the PCM?
OR is that signal really needed? The truck will be more of a toy and not a daily driver, but will be driven to work on occasion.
Old Jan 19, 2017 | 11:49 AM
FlatBlack's Avatar
I'm running a LM7 in front of a NV3500. I didn't hook up my VSS, I just use the Torque app on my phone (it uses GPS) for my speedo and gauges.
Old Jan 19, 2017 | 12:03 PM
Project GatTagO's Avatar
A stock PCM will use the VSS as part of adjusting certain parameters. Mainly for certain IAC setting. On the GMPP harness (E67 ECU) that I am using in the GTO, the VSS is listed as being optional. Having said that, on occasion, when I come to a stop after a prolonged period of driving, like taking an exit off the highway, the engine will die when I put the clutch in and coast to a stop.
Andrew
Old Jan 19, 2017 | 12:25 PM
aggie91's Avatar
Not worried about the speedo, the trans has a mechanical drive to run the stock speedo in the dash.
Andrew
That's the part that I am worried about. I just wonder how much of an issue that would be with an auto and street driving...
Dakota Digital makes a 8K pulse generator that is a pass through that can run my mechanical speedo too. That might be what I need to do.
SEN-01-4160 - 8K pass-through pulse generator with adaptor cable for GM transmissions with cable drive speed output.
Old Jan 19, 2017 | 01:26 PM
2ToeRacing's Avatar
Its been a while ....but I know it does exist. back in the 90's the 700/4L60 had a 2 prong speed sensor that you might look into.
Old Jan 19, 2017 | 01:27 PM
76larkman's Avatar
some of 80s and 90s cars had a speed sensor on transmission that worked off speedo but then speedo cable went in that. I wander if something like that would work
2ToeRacing's Avatar
this is it
Replacement ARBC313302 Speed Sensor - Vehicle speed sensor, Direct Fit
Old Jan 19, 2017 | 01:46 PM
garys 68's Avatar
The Dakota digital pass thru VSS WILL prevent stalling issues, at least with manual trans.
The ecu does not need to be tuned to the correct speed.
I have 2 conversions that had the exact symptoms above. The DD VSS cured it.
Old Jan 19, 2017 | 02:18 PM
aggie91's Avatar
Looks like the DD sensor is the one I need. I found this one too on ebay, but not sure it is a pass thru to allow me to keep my mechanical drive speedo.
http://www.ebay.com/itm/351945485671?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jan 19, 2017 | 03:48 PM
garys 68's Avatar
One other note, the DD VSS sticks out quite a ways from the trans, the one above looks as large. If you don't have clearance, you'll need a short extension speedo cable that DD has but doesn't list on their website.
Old Jan 19, 2017 | 06:40 PM
Lsxford's Avatar
What kind of vehicle are you swapping?
Im in the middle of a early 90s ford vehicle with rear abs, i tied the vss into the rear abs speed sensor in my diff. It works also, spinning it as fast as i could it showed max of 5 mph on my tech2 and then slowed back down correctly. It seems pretty accurate even tho idt it has to be. (I have mechanical speedo also) like some1 said previously pcm just need to see a signal that car is or isnot moving. Hptuners can adjust this also and get it closer.
If you have an older vehicle without abs then this wont help you. But i think it is interesting that it seems to work lol
Old Jan 20, 2017 | 09:32 PM
-TheBandit-'s Avatar
My e38 ecm will not directly read the Dakota digital vss I installed on my th400 because it is expecting an automatic Tcm to read the vss and send the signal over can bus. Some people have gotten it to work but my tuner tried a number of settings without luck. With a th400 I have so far seen no ill effects but I also have less than 200 miles on the car since swap.
Old Jan 21, 2017 | 07:31 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
jagsthatrun has what you need.
Old Jan 21, 2017 | 08:56 PM
gofastwclass's Avatar
An E38 it expects a square wave and not a sine wave. You need something like an SGI-5 to convert the output to a square wave.
Old Jan 22, 2017 | 10:13 AM
garys 68's Avatar
Are all gen 4 square wave now?
Old Jan 22, 2017 | 02:43 PM
Square wave is Hall Effect 3 wire sensor? Sine wave is 2 wire sensor?
Andrew
Old Jan 22, 2017 | 02:57 PM
truckdoug's Avatar
I have set up a 5.3/th400 swap and deleted the VSS. ran fine. dude eventually added that VSS pass thru thing so he could make the cruise control work.
Old Jan 22, 2017 | 04:30 PM
garys 68's Avatar
Correct, I didn't realize they changed them. All my stuff is pre 07 truck.
Andrew
Old Jan 22, 2017 | 08:58 PM
Michael Yount's Avatar
I know on the T56/LS3 Corvette set ups, the VSS sensor is a 2-wire (sine wave) VR device -- magnet stationary/ferrous trigger moving - toothed wheel in tranny, not a Hall-effect sensor (pickup stationary, magnet moving). Any conversion to a square wave signal that might be needed (for example by a speedo) occurs, I think, in the ECU. Can anyone confirm whether or not the factory speedos need a square wave vs a sine wave signal? I know the Corvette ECU is looking for a sine wave signal, not a square wave.
I made a multi-tooth reluctor to be mounted on the rear pinion flange and positioned a stock T56 VSS sensor on the rear end to read that reluctor. Works just fine for the ECU's purposes. However, Dakota Digital urged me to use their cruise control set up designed to receive a simple sine wave/Hall effect signal generated by two magnets on the driveshaft. So my cruise input and my ecu input are provided by two different sources. Drivability and cruise function are both flawless.
To the OP - I'd create something that mimics the VSS in whatever tranny came behind the ECU you're running. The ECU will get the speed signal it's expecting.
Old Jan 22, 2017 | 09:22 PM
My e67 ECU that I have as part of the GMPP harness kit is definitely looking for a sine wave (VR type, 2 wire) sensor. I've never seen any OEM GM computer was a 3 wire sensor...
Andrew
