Want to run LS3 intake?
Old Feb 27, 2017 | 10:13 PM
cula8r's Avatar
Default Want to run LS3 intake?
Guys, I'm a newbie to the LS platform ......I run a SBC in my 1st gen Camaro and am going to eventually switch to a Gen III 6.0L with LS3 heads and intake. Did some research and I believe I need to get a throttle adapter to utilize the Silverado gas pedal. Any input or suggestions from someone who has experience running this setup are appreciated. Thanks in advance.
Old Feb 27, 2017 | 10:15 PM
cula8r's Avatar
Apologize if I posted in the wrong section.
Old Feb 28, 2017 | 07:54 AM
showdog75's Avatar
You need to be specific on the years of the gas pedal.
Old Feb 28, 2017 | 09:31 AM
cula8r's Avatar
From 2003
Old Feb 28, 2017 | 06:21 PM
Project GatTagO's Avatar
The simplest option would be to go with the LS3 intake and an aftermarket 4 bolt cable TB.
Andrew
Old Feb 28, 2017 | 08:24 PM
EastTnZ28's Avatar
Andrew
^^^^This is the answer
Old Feb 28, 2017 | 09:45 PM
cula8r's Avatar
Thanks guys, I have a wire driven pedal setup now for my carb.........I'll post up again regarding suggested injectors and throttle body diameter using this Lunati cam.
http://www.lunatipower.com/Product.aspx?id=2024&gid=288
Appreciate it.
Old Mar 1, 2017 | 11:48 AM
hookemdevils22's Avatar
The stock 42 lb/hr LS3 injectors are plenty for the vast majority of NA builds, and you can essentially pick a 4-bolt 90mm throttle body if you're going cable-driven.
Old Mar 1, 2017 | 03:28 PM
mcdonald77's Avatar
I used an 04 harness from a silverado along with the pedal and tach module. Then I used an LS2 TB and a torque rush x-link module.
Old Mar 2, 2017 | 02:32 PM
ryeguy2006a's Avatar
If you have the matching TAC, Pedal and ECU, that is how I would set it up too.
Old Mar 2, 2017 | 03:50 PM
mcdonald77's Avatar
---not to go off topic but I love the camaro project you got going!
Agreed, just need to get a throttle body adapter to bolt up the 3 bolt truck throttle body to the LS3 intake.
