Old Mar 2, 2017 | 01:17 AM
85blackc-10's Avatar
Default 2015 5.3
Hello, I'm new to the site. I'm putting a 2015 5.3 motor in a 85 chevy c-10 1/2 ton 2wd. Wanting to know what trans to use any other things I will have to do to it? First time installing fuel injected motor. thanks in advance.
Old Mar 2, 2017 | 02:57 AM
RelentleZ's Avatar
Working with a DI motor is a big step if you've never done a fuel injected swap. It's big even if you have. I've been researching a bit off and on about the L83 and would really like to tackle a swap with one within the next year or so.
Some info I've found that may help get you started:
http://www.hotrod.com/articles/under...stem-swapping/
https://ls1tech.com/forums/conversio...-pin-outs.html
Hope this helps. There are a few guys here that have accomplished this task thus far. Good luck.
