LS Ford Focus
Old Dec 18, 2017 | 06:03 PM
  #61
topspeed1's Avatar
I decided to go a different route on the build.
I bought a 6.2 ls3 block and I am going to build a high compression 6.2.
I also made a little more progress on my headers. Hopefully I will have time over the holidays to finish them,
I also put my current engine up for sale if anyone is interested
https://ls1tech.com/forums/parts-cla...-complete.html
Old Dec 20, 2017 | 12:30 AM
  #62
Number Tew's Avatar
Those headers look awesome. I bet that 6.2 is going to be crazy in there!
Old Dec 24, 2017 | 10:40 AM
  #63
Tig's Avatar
Tig
A 6.2, NICE! Is it going to be n/a with the 6.2 or is boost planned for the future?
Nice job on the headers, lookin good so far. Cant wait to see the end result.
What are your plans for the 5.3?
Old Jan 17, 2018 | 07:58 PM
  #64
topspeed1's Avatar
Probably gonna be NA for a while.
Old Jan 17, 2018 | 08:02 PM
  #65
topspeed1's Avatar
Got some parts in this week.
JE +10 Dome Pistons.
ICT billet intake manifold
Trick Flow 255 heads
Should have around 13:1 static compression.
gonna pick up the block from the machine shop on friday.
Old Jan 21, 2018 | 04:19 PM
  #66
Tig's Avatar
Tig
Sounds good,
What machine shop did you use?
Old Jan 22, 2018 | 11:06 AM
  #67
topspeed1's Avatar
Sounds good,
TAS Racing Engines in Winterville, NC
Old Jan 25, 2018 | 06:00 PM
  #68
topspeed1's Avatar
got the block back from the machine shop today. Decided to finish up my new motor mounts and make sure my headers still fit correctly with the motor slightly moved.
I know they are cathedral port heads in the picture with a rectangle port manifold
Old Jan 25, 2018 | 11:23 PM
  #69
seanb128's Avatar
Awesome build! +1 on the fab skills!
Old Jan 28, 2018 | 02:35 PM
  #70
topspeed1's Avatar
Finally got some time to weld up the headers.
Old Feb 6, 2018 | 05:17 PM
  #71
topspeed1's Avatar
got the exhaust mocked up today.
dual 3 inch stainless with magnaflow mufflers
Old Feb 10, 2018 | 08:17 PM
  #72
Mcnally351's Avatar
Very cool build
Old Feb 11, 2018 | 04:34 PM
  #73
Romulus22's Avatar
Exhaust looks good. Look forward to more updates.
Old Feb 19, 2018 | 10:52 PM
  #74
topspeed1's Avatar
A couple of small updates.
Been mostly waiting on parts.
Got the short block assembled.
New Wheels and tires arrived.
Johnson Short travel lifters showed up.
Old Mar 1, 2018 | 07:11 PM
  #75
topspeed1's Avatar
Made a little more progress. hopefully have it running this weekend
using fast 85lb injectors
Old Mar 3, 2018 | 07:39 PM
  #76
topspeed1's Avatar
Got the fittings welded on the valve covers and powder coated. Also got the catch can built. Just waiting on a few random parts. In the short roads now.
Old Mar 22, 2018 | 08:08 PM
  #77
topspeed1's Avatar
Got the motor on the dyno a few weeks ago and made 550whp, not exactly where i wanted to be but still go. I think i was having valve float issues.
I then put in stiffer springs and ran it again. At that point i had a piece of valve guide break off and fall into the motor.
It caused mild damage to one of the pistons and damaged the head.
The heads are at a machine shop getting repaired.
While the motor is apart i decided to switch to a solid roller cam.
I ordered a custom cam from cam motion.
I cant wait to see the results
The low numbers at the begining of the dyno chart are from me rolling into the throttle to prevent wheel spin.
Old Apr 1, 2018 | 07:15 PM
  #78
Number Tew's Avatar
Interested to see the solid roller setup. How high are you trying to spin it?
Old Apr 2, 2018 | 08:06 AM
  #79
topspeed1's Avatar
Im thinking around 8000rpms. But I just have to wait and see when the power falls off
Old Apr 2, 2018 | 08:16 AM
  #80
topspeed1's Avatar
I checked the cc's of the heads since he had to cut them to repair the damage.
Motor is closer to 14:1 now which is what i was originally shooting for.
Also my Cam Motion llsr cam came in
Im still waiting on my shaft mount rockers to come in.
