anybody put a LS1 into a OBS (88-98) chevy 1500 truck.
just wondering mainly about the AC compressor and other problems i will have. the truck i got is a 4x4 1996 Z71 with a worn out 5.7 vortex. the wireing will not be a problem. just need info on the fittment problems. will the AC or other accesseries hit the crossmember? what other problems will i have or has anyone ever done this?
http://www.stang.cc/tmcagallery/album01
theres some pics of my 98/98 swap. a/c wont clear the frame.
this pic is allens(farmtruc) truck a year or so ago when he had some bracket on there.
the only other problem with fitments you'd run into are your motor mounts. S&P makes relocating plates but that changes your angles which i didnt like too much my mounts are a bit custom and sit in the exact same location my old motor sat.
awsome man. i figured the compressor would not fit, but i have a 4x4 with a little bit more clearence then a 2x4 will. eather way, running the compressor with that bracket up high is a good idea. i could probably just use the orignal 96 compressor if i do it that way so i dont have to buy another expensive LS1 compressor. did the oil pan clear fine? and what wireing harness did you use? i was thinking about useing a facotry harness and just splicing it into the origanal one. let me know, thanks. my origanal 350 vortex already has 210,000 miles on it and starting to lose oil pressure.
best pic i could find of the clearance.
as for the wiring...id go speartech just for his tech help on here...painless isnt all that painless when you cant get a hold of them.
Originally Posted by L-EATER
Here is a pic of mine when I was doing the swap. Just had to get out the old sawzall.....can make anything fit with that!!!
i dont wanna cut my frame so im gonna use a custom bracket to pull my a/c up higher rather than switch all my accessories to truck accessories and have to run the truck intake.
truck brackets may be ok for you in the case of 4 wheeling, but for racing ill take the ls1/6 intake over a truck intake.
