72 Chevelle LQ4 Swap Recommendations
Looking for some recommendations
Thanks in advance!
72 Chevelle
LQ4
-stock rotating assembly
-stock heads
-FAST 92MM Intake
-FAST 92MM Throttle body
-42lbs injectors
-230/228 .612/.588 LSA 111 +2
-long tube headers
4L80e
-monster transmission rebuild
-monster 2300-2500 HD stall
12 bolt
-posi
-4.11
275/60R15 in the rear
28X11R15 slicks for the track
Best track time is 12.813 (street tire)
She weights 3920 lbs with driver, fuel, and full interior. She made 427HP (6050 rpms) and 432lbs (4900 rpms) on the dyno.
I am looking to wake it up and make it down the track a little faster and more fun on the street!
At the track I had to run street tires because my first set of slicks 29.5X11.5's were too tall and slowing me down on the top end. The street tires did spin into 2nd so I know with the smaller slicks it will gain some time.
My personal thoughts are to change the torque converter to a higher stall and tune it. It is lame off of the line. I am not super well versed in where to take it next. I am not looking to put a turbo, supercharger, or spray on it yet.
Please let me know what you would recommend.
Mike
Thanks in advance!
72 Chevelle
LQ4
-stock heads
-FAST 92MM Intake
-42lbs injectors
-long tube headers
4L80e
12 bolt
-posi
-4.11
Mike
Thanks for your input, What would you consider to be to steep for a stall on the street?
Mike
Anything over 4000 depending on converter size just isn't as nice to drive anymore.
You could always swap heads. 243 or 799 heads would give you almost a full point of compression. Would make a noticeable difference in torque.
Who would you suggest?
Thanks
