Gauges and sending unit question
Old Jul 1, 2017 | 01:35 PM
SlmLrd's Avatar
Default Gauges and sending unit question
Hi group, Hope this is in the right section.
I have a 2005 Tahoe 5.3 motor and Im trying to hookup my 1940 Mercury gauges... The oil pressure is a 50 lb unit and Im not sure of the temp specs. I already purchased the stock gauges, and can add adapters to fit my LS, but the temp gauge is twice as long as the stock sender.
I guess my question is can I use newer temp and oil sending units, or would it be best to install the stock units, and does the degree rating of the sender matter for a sweeping L | H type gauge?
thank you.
Old Jul 1, 2017 | 02:05 PM
KCS's Avatar
KCS
Moderator
Nope, it's not. I'll move it for you though.
Old Jul 1, 2017 | 02:11 PM
tfi racing's Avatar
The 2005 5.3 senders will be of no use with those gauges,if you dig around a bit on the hot rodder forums you should be able to find a smaller temp sender that will work with your 1940 gauge,however you will need to tap the other cylinder head or perhaps mount it in the rad hose with an adapter.
Old Jul 1, 2017 | 02:20 PM
SlmLrd's Avatar
thank you
Old Jul 1, 2017 | 02:52 PM
SlmLrd's Avatar
so does a temp gauge read temperature, resistance, both? A SBC 220 degree sender that is the right length with a proper adapter won't work?
(Gauge is fitted with a voltage drop 12-6v as well)
Old Jul 1, 2017 | 07:36 PM
tfi racing's Avatar
As long as the gauge is seeing the resistance range it needs,that sensor should be fine.
Old Jul 1, 2017 | 09:58 PM
SlmLrd's Avatar
Guess Im on the hunt for a temp sender that has the same resistance....
Old Jul 2, 2017 | 08:39 AM
ls1nova71's Avatar
Good luck with finding the correct sender for that gauge. Temp sender ohm ranges vary A LOT between different vehicles and there are a lot of them out there so you'll have some searching to do. Do you know the ohm range of the stock gauge?
Also, you're most likley going to peg that oil pressure gauge every time you start it. I have a 60lb gauge in my truck and it pegs when its cold.
Old Jul 2, 2017 | 09:20 AM
33willys's Avatar
Default Gauges
If you want to retain the original gauges there are companies that will convert them for you. The amps gauge will be converted to volts, gas gauge will read correct and the speedo will be converted to electronic. This isn't cheap but you will not need a bunch of gauges dangling under the dash. If you decide not to go this route do not hook up the amp gauge due to fire hazard. The old electrical system would generate 30 amps tops and the new 12 volt system with fans and a/c will be double that. The gauge just can't handle it.
Old Jul 2, 2017 | 10:34 AM
mytmouz's Avatar
The LS temp sender hole in the head is 12mm x1.5 mm. I purchased an adapter from that thread pitch to 1/8 npt for a sender that would work with the factory gauges in my 67 chevelle...
Old Jul 3, 2017 | 01:27 PM
SlmLrd's Avatar
Thank you. Im probably going to add the stock temp sender either in the heater hose delete, or add it to one of my Rad hoses. Well see how the oil pressure gauge goes. 50# in my 1940
Old Jul 3, 2017 | 01:32 PM
SlmLrd's Avatar
thank you.. Ive checked around, and its not enough of a big deal to spend that kind of $$ on the gauge conversion right now. I can hide things pretty well if it comes to that. I was reading up on adding a resistor to help the amp gauge see a reasonable amount of amperage.. Not that big a deal either, but Ill just keep reading
Old Jul 3, 2017 | 01:33 PM
SlmLrd's Avatar
I also looked into that, but the stock probe is larger that the adapter, haha!
Old Jul 3, 2017 | 02:53 PM
Project GatTagO's Avatar
Have a bung welded (braised...whatever) into the tank of your radiator.
Andrew
Old Jul 3, 2017 | 04:02 PM
Michael Yount's Avatar
As Andrew suggested -- I have all the VDO/Volvo analog gauges working on my swap by simply using the matching sender. You should be able to find the proper adapters and/or figure out how to add the appropriate sender in the right place. I have two different temp gauges, oil temp, oil pressure and the oil pressure idiot light all working just as if the stock Volvo engine was in the car. I had two bungs welded into the radiator for coolant gauges, I drilled/tapped an oil cooler fitting for the oil pressure and idiot light and was able to find the correct sender for oil temp gauge in a 16mm thread that screwed right into one of the threaded passages in the block oil casting (right above the filter). I'd post pictures -- but Photobucket is raping me right now.
Old Jul 3, 2017 | 07:03 PM
mytmouz's Avatar
I used the sender that came with my Shiftworx gauges...
Old Jul 3, 2017 | 09:14 PM
ls1nova71's Avatar
Odds are that even if you use the stock sender it's going to read more towards the H than the N on the gauge since newer engines run hotter than older ones. Since the gauge just has C N and H, I would think if you know the gauge ohm readings for cold and hot, you could split the difference and come up with a sender that would put the needle in the Normal range when the engine is at operating temperature.
Got any pics of the car this is going in?
Old Jul 3, 2017 | 10:51 PM
....and purely a guess here - but for all the newer stuff, the sender is designed to send a signal to the ECU/body computer -- and it manipulates it and sends a signal to the gauge. I know on the tachs -- it's a 5V signal. So that has to be dealt with if you're using an older tach that's expecting a 12V signal. I'd guess the same is true of the other gauges -- they're set up for 5V signals. So I'm wondering if you could use the contemporary senders with 1940 Mercury gauges at all.
However, to Nova71's point -- my car's original gauge/sender was expecting a lower operating temp than the LS3 runs at. So I had to install a small resistor in the gauge signal line to move the coolant gauge needle from the upper end of the range, to something closer to the middle under normal operating conditions. So now, when I'm under cruise and the head temps (from ECU data read) are around 195F - the gauge shows a bit below halfway. And when the fans are controlling temp (head temps around 199F-202F) the gauge reads just a bit above halfway.
Old Jul 5, 2017 | 12:13 PM
Suncc49's Avatar
Are you keeping the stock ECU? You can run temp gauges and such with the stock ECU and a bluetooth OBD2 adapter with a cellphone or tablet application called Torque Pro
Old Jul 5, 2017 | 01:04 PM
I believe his goal is to keep his stock gauges. From the initial post -- "....Im trying to hookup my 1940 Mercury gauges... "
