Cayman LS3 Swap
Let us know your impressions as far as streetability and tunability are concerned.
Thanks......and nice work, BTW
KW
I'll definitely update regarding streetability / tunability once we hit that stage. Michael is right, it's not meant to be a daily by any means... so not my priority.
Cooling - running 3 radiators & the Meziers electric pump. I don't have high hopes for it keeping up on the track, especially in the Texas heat... but we'll cross that bridge when we get there. There are options for a remote mount mechanical pump - but at least in my case it means giving up my A/C. (not a big concern for the track purpose... but I did want it to be 'comfortable' for weekend cruises too)
Video of the car:
Sound Clip:
One thing you might consider is swapping over to the slightly smaller 87mm 4 bolt truck throttle bodies. A LS3/525 doesn't need anywhere near the airflow of dual 90s and will hurt drivability.
If you keep having issues with a stock ECU, it might be time to get a Holley Dominator with native support for dual DBW throttle bodies and the means to tune them for excellent drivability.
Andrew
You'll likely see it a bit more often. You can find older Caymans/Boxsters with blown motors for <$10k these days. The swap is fairly straight forward if you use the stock intake... it mostly fits with minimal cutting.
Not cheap - but for a light, mid-engine car with V8 torque, it's not too bad.
Andrew
The ECU - this one I've sort of regretted sticking with the GM. I've been eyeballing a standalone, inc the Holley, for the reasons you state. Originally, we stuck with the GM ECU for the OBD port to "pass" inspection. Now that we've been through that process, it definitely wasn't necessary... so may end up going back through and getting a standalone. Probably will get added for stage 2 of the build.
And Project GatTagO has hit the nail on the head as to why we went with the dual TB. With the LS, we knew going in that swapping the intake wasn't going to be a major power addition... but it really makes that engine bay pop! Turned out to be an expensive cosmetic upgrade in the end... still worth it.
http://www.torquerush.com/x2.html
Tried the one from Ozmo engineering - that one died, and the company went unresponsive. Then picked up the x2 and working well.
I've had it on the road more than a few times, and it is an absolute blast to drive.
