Gen 3 5.3ls , will a 1995 t56 bolt up ?
Hello everyone, I just found a T-56 Magnum F from a 95 camaro, 0.50 6th gear ratio. Comes with hydraulic slave, clutch and flywheel for 1st gen sbc with less than 2000 miles on them. A 57" driveshaft with 1350 u-joints . Will this thing bolt up to my 2005 gen 3 5.3 ? Or do I need to do bunch of modifications to the transmission like the input shaft and etc.Apparently the owner converted it to work with his ls2 engine . That is the last engine that the trans was used with. Therefore, will it work just fine with the 5.3? Will 5.3 accessories like clutch flywheel and throwout bearing work with this trans ?
Thank You for taking Your time and reading this, hopefully someone can help me out
