Cayman LS3 Swap
It was suggested I put up a build thread for my LS3 swap. This project started ~1 year ago as a result of a blown motor. After 96,000 miles, she gave up at the track in Texas heat. We considered a 3.8 swap, turbos, etc... and finally decided on the LS3 swap.
The car is being built for weekend track / HPDE duty... street legal enough to drive to weekend meets. It's being built by Modern Aircooled in Houston (fabrication @ Euro Race Concepts).
Car: 2006 Porsche Cayman S
Engine: LS3/525 from GMP
Intake: Edelbrock Crossram
Oil Pan: Corvette + Improved Racing baffle/windage tray
Transaxle: Original 6MT from the Cayman S + Guard LSD
Power Str: Pump from Vauxhall Astra
Others: Rear cage, Accusump, 3rd Radiator, BBK Shorty Headers, Borla XR1s, and other bits
Currently getting the exhaust fabricated, then will be either going for paint or to get the motor up and running.
The Cayman from the outside
Shift cables being routed
Custom intakes in the rear, being fed from side vents.
The LS3/525 with Edelbrock CrossRam that is going in the car.
Things may be delayed due to the floods in Houston, but hoping to have it ready towards the end of November.
I'm from Houston, that's where my car is being built. I'm on an assignment in Norway for a couple years (1 down, 1-2 more to go). Engine blew right before I left, so it's a good time for it to be in the shop for a small overhaul.
Here's a few more. If you're looking for anything specific, let me know, I've got quite a few more.
1.) Engine from driver's side window, panel removed
2.) Engine Mounts
3.) Front panel removed (everything is built so it can be worked on easily)
4.) The divider panel roughed in
5.) From the underside...
When someone else is doing the work, always makes it tougher to get all the pics you might like to have.
The transaxle has shown to hold up for others pretty well. Unfortunately there's not a whole lot of experience out there yet. Apparently though, it's built off the design for an Audi diesel - with some pretty robust gears.
The only failure(s) I know about are with a guy racing his Cayman with TT 4.0L. Similar torque levels. He's upgrading to an Albins sequential. I'll probably follow suit if mine grenades, but too much $$ to put down for now.
You'll likely see it a bit more often. You can find older Caymans/Boxsters with blown motors for <$10k these days. The swap is fairly straight forward if you use the stock intake... it mostly fits with minimal cutting.
Not cheap - but for a light, mid-engine car with V8 torque, it's not too bad.
rn it over for the first time (and hopefully start)next week.
Now - there's always surprises... but everything is plumbed, wired, and ready to go.
