Adapter - Does is exist?
If I can't find it, I don't think there is enough material to drill-out one 1/8" NPT and tap it to M12x1.5. As best I can tell, 1/8" NPT requires an 11/32" drill bit while a M12x1.5 requires 10.7mm, which is equivalent to 27/64".
The metric hole is only 5/64" of an inch larger...just under 2mm. I don't think that's enough to drill and tap?
Tipsy
I'm keeping the stock LS2 sender that's behind the manifold so I can read pressure on an AeroForce scan gauge I'm going to use. The other two senders are for a standalone aftermarket oil pressure gauge and the stock instrument cluster "idiot" light.
Tipsy
Tipsy
Tipsy
http://www.ebay.com/itm/LSX-Oil-Pres...JU5SRH&vxp=mtr
I'd prefer to find a solution that would allow me to keep a single sender up top and two down at the oil pan.
Tipsy
The 1/8" NPT sender came with the Prosport oil pressure gauge.
Tipsy
Tipsy
Tipsy
This gives you two 1/8" NPT ports and one M12 port, just choose the M12 adapter fitting option.
The reason an adapter is hard to find is because M12 is larger than 1/8" NPT, so the adapter will add a lot of length to the port.
Tipsy
Just not sure how well it would work having one of the fittings sticking out horizontally, with regard to header clearance. I guess I'll have to get the engine and header back in the car again before choosing which adapter to use.
Tipsy
