Another Twin Turbo Chevelle
#41
10/12/17 Got a call from the shop doing the tuning. During its 3rd pull it made 754 and 709 tq at the tire on 7lbs of boost. Then something went really bad. The engine would not turn over and there was signs of metal in the exhaust. They pushed it outside and later that day it was able to be turned over. We towed it back home and began tear down. We found a lot of metal in the intake and when the heads came off we found #8 rod broke and #7 piston gone. Also #1 had a crack in the piston. It was determined that when I re-built the engine a few years ago I bought new GM ring kits and never checked the gap. When we installed the turbos we never opened the rings up. It was my fault and my fault alone. The tuner is not responsible for my mistake.
