LS3/T56 magnum swap 68 firebird, tunnel mod?
I am getting ready to install an LS3/T56 magnum into my 68 firebird. I have the connect and cruise package from GM and swap kit from holley (engine mounts, tran crossmember, etc)
Question: Does this setup require modification to the tran tunnel (other than a simple hole for shifter)? If so, where and how much of tunnel to cut and remove?
Moderator
Received 1,852 Likes
Dude that's a cool as **** build!!!!
Honestly you'll probably just need to beat the **** out of the tunnel with a 4 lb sledge.
Location: Coast of San Mateo County Between Pacifica & HMB
Check the conversion & hybrids section and search 68 Camaros.
Carbuff did a 71 Firebird with a T56 I believe, but lots of
Early Camaros out there with T56 I would guess,
Especially G/Pro Touring Forums.
