Why the "LS2" cover
Old Aug 9, 2017 | 03:32 PM
G.I. Turbho's Avatar
Default Why the "LS2" cover
So I have been pondering for several days now, why does everyone use the LS2 front cover? And on top of that, is there a difference between the LS2 front covers? Like the '05 LS2 front cover with PN: 1260 0325, and the GEN IV LS2 front cover with PN: 1263 3906?
And then, what is the difference between them, and the other GEN IV front covers? Such as this one from an '08 Tahoe engine with a PN:1260 0326
I've tried to compare pictures, but pictures don't tell you measurements. So......that is where I sit.
If anyone could shed some light on this, it would be much appreciated
Old Aug 9, 2017 | 03:48 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
The "ls2 cover" is originally used on the ls2 but works with ANY ls wet sump engine. It also comes on every wet sump ls3 engine, quite a few 4.8, 5.3, and 6.0 gen4 engines and a few 6.2l truck engines as well, So its not JUST an ls2 front cover but that was the first appearance of it.
It has the cam sensor in the front to pickup the reluctor mark on the cam gear. it works the same whether you use a 1x cam gear or 4x cam gear.
The complete ls2 front cover comes with cover, crank seal (installed), cover gasket, bolts, cam sensor, cam sensor harness, and harness bolt. its literally a complete assy.
The 12600326 is bare. cover only
The new pn for the complete cover ia 12633906.
They have to be used on all gen4 blocks and the gm lsx block.
The truck front covers utilize the vvt cam phaser on the front of their engines and that cover includes that. So any vvt engine has to have that.
IF you are removing vvt, you swap to the ls2 front cover kit.
Thats it.
Old Aug 9, 2017 | 04:02 PM
Alright. Thank you.
If you had a GEN IV front cover that was a DOD engine, pre VVT, then would it work? The sensor location is the same. No VVT components. And would it still clear a 4x 3 bolt cam gear?
Old Aug 9, 2017 | 04:06 PM
A DOD/AFM only engine uses the ls2 front cover. There is no "fitting or not fitting" a 4x cam gear. they will all fit any cam gear.
The vvt engines use a different cover but only because the electrical part of the phaser is in the cover.
Old Aug 9, 2017 | 04:08 PM
Much appreciated.
Old Aug 9, 2017 | 04:14 PM
Project GatTagO's Avatar
I believe all Gen IV front covers that are non VVT are the same...so LS2, LS3, LH8, etc...
Andrew
Old Aug 9, 2017 | 07:05 PM
Thanks for your input gentlemen
Old Aug 10, 2017 | 02:29 PM
ryeguy2006a's Avatar
Also something to keep in mind is some cams are 1 bolt and some are 3 bolt. Not sure what motor you are running, but there isn't a 1 bolt 4x cam gear stock. They may make something aftermarket, but not sure why they would bother.
Old Aug 10, 2017 | 03:02 PM
You have that backwards. There is no single bolt 1x cam gear.
Old Aug 11, 2017 | 10:30 AM
Correct...
Andrew
