Using M6 PCM retuned for A4, what to do about wiring and sensors?
I heard you can use the stock M6 PCM and tune it for an auto but what do you do about the wiring for the sensors and stuff? Thanks,
Wes
Wes
You still need a auto harness or you need to have the harness reworked like I had done. The pcm will just be reflashed to an auto program and then tweaked to remove the problem error codes.
