lq4 blue/green harness + 4l80
Hi guys
Starting on a new harness modification. its a 2003 lq4 harness with blue/green connectors from PSI.
Trans will be 4l80.
Wanted to know what Green pin 42 TCC Solenoid Valve Control goes to? Its a tan wire
Right now, it looks like it goes to one of the 4l80 VSS's (tan/orange wires)
Is that correct?? If not, where is green pin 42 supposed to connect to?
Doesnt match the lt1swap that ive used in the past.
And, where is the other VSS supposed to connect to?
Extra information:
green 20/21 are the green/purple VSS to trans
green 22/23 are not currently being used
thanks guys
Trans will be 4l80.
Extra information:
thanks guys
little more research points me to the TCC Solenoid Valve Control should be pointing to pin T in the big round trans connector?
And currently, there no pins in trans connector T,U,V,W.
Did PSI mess up here?
Shouldnt T be connected to green 42?
Shouldnt V be connected to green 2
And should the orange/tan wires of the second VSS go to green 22/23?
ok .. some progress.
according to this:
http://lt1swap.com/4l60e_4l80e_harness.htm
green pin 2 goes to trans connector pin s. which it does
But, the ISS connector (PSI tans and orange wires) need to go to green pins 22/23. So looks like PSI did half the job.
lt1swap rules!!
according to this:
lt1swap rules!!
