S-10 Xtreme 6.0 LSA supercharged
#41
I haven't had it on the dyno so I have no idea. My conservative guess would be in the 500-550hp at the wheels.
A stock ZL1 makes 580 crank hp with 376ci and 9:1 compression, Where my engine is an LY6 with 364ci and 9.6:1 compression a bigger cam E85 and better exhaust.
#42
Beautiful truck! I always wanted an xtreme.
Is that intercooler from frozen boost? What do your IAT numbers look like, are you running E85, and where did you mount your power steering reservoir?
#44
My power steering reservoir is mounted between the alternator and inner fender, It the only spot I had left lol.
#45
Man that's pretty bad *** overall. I really like how you narrowed the rear frame and did the rear tubs. I may have to use that idea on my 97 S-10 5.3 Twin Turbo build that I'm working on right now. You did a great job overall!!
#46
Thanks, It started out to be a simple swap and took off from there. The truck itself wasn't built to be a long term build, I built it thinking I would probably pull that body off and swap the chassis and driveline under one of my 51 Chevy trucks. I just can't see spending the money on body and paint for a S10.
#47
It's hard to tell from the angle, did the AC compressor actually fit without notching the frame?
Also looks like it would've been nice to have the radiator fill neck positioned a little differently, looks pretty tight even with routing the intake tube under there.
Clean swap, nice work!
#48
The frame had to be notched. The filler neck is in the way a little but not that bad, It would have been better to have it on the other side of the radiator.
Everything is a tight fit but I can still run a stock hood if I want to.
#50
You may have just built my Dream Machine LLLosingit, Beautiful Truck, AMAZING JOB ![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
I've had many Performance Trucks and recently sold my 94 S10 SS with a Gen II LT1 5.7L / 700R4 and every option known to man kind, it was an amazing truck. I sold it to a friend and I still hang out with it a few times a week at car shows. Out of the stupid amount of Performance Vehicles I've owned 13 have been Pick Up's, 10 were Supercharged, 1 Turbo'd. Although I don't have a truck at the moment there is just something about whooping someones *** in a truck that I find extremely rewarding. And once you've been blown there's no going back ....
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
#51
I've had many Performance Trucks and recently sold my 94 S10 SS with a Gen II LT1 5.7L / 700R4 and every option known to man kind, it was an amazing truck. I sold it to a friend and I still hang out with it a few times a week at car shows. Out of the stupid amount of Performance Vehicles I've owned 13 have been Pick Up's, 10 were Supercharged, 1 Turbo'd. Although I don't have a truck at the moment there is just something about whooping someones *** in a truck that I find extremely rewarding. And once you've been blown there's no going back ....![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
#53
What brand truckbed lining did you go with? It looks killer. Once spring rolls around, how about a video seen from a 3rd person of a holeshot and one with you getting on it from about 30 MPH. Who doesn't love action videos? LOL
#54
I haven't posted any video's anywhere, I have a couple and neither are really all that impressive lol.
#55
wow. LOL. Talk about a great score. How much did you end up using on the bed? I would of used in on the inner wheel wells, floorboards and frame as well. Really got your $9.00 worth. LOL
#57
Lllosingit
do you know what’s different on the GM modified LSA FEAD vsa stock Vette FEAD? I have a LY6 and GM Vet FEAD I don’t want to have to buy much if I bit the bullet and bought a rebuilt SC. Did you buy you swAp harness ready for the sc or did u change it to suit
#58
Lllosingit
You can look at these pictures and see the difference and look at yours and see it it's going to be an issue.
Standard LSA
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/500x500/809_19368947_46936fd5dc2bb32e2062db961e099d55afb90437.jpg)
Modified LSA
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/586x357/modified_lsa_accessory_drive_package_specifications_2834334_1_04f1a22af0ddb91199f3a26c5153342a6ad9ec80.jpg)
The wiring harness didn't have to be changed but I use the Holley system. The only thing that plugs in on the supercharger is the MAP sensor.
#59
The modified LSA looks to be the Vette IIRC At least it looks like the FEAD Im running.
#60
LLLosigit,
since you bought the modified LSA FEAD new, would you happen to have the parts list from the instructions? I called Pace Performance hoping the could help me, but that guy couldn’t be bothered
thanks,
jim
thanks,
jim
